p-tuning axle back Idle noise
Old Feb 9, 2011 | 06:02 AM
STlTCHES's Avatar
Default p-tuning axle back Idle noise
After installing the p-tuning axle back on my 06 tC I'm getting a tapping noise/vibration coming from what i swear is right under the arm rest. This happens only at idle even after warmed up. When moving at any speed the noise goes away. Does anyone else with the P-tuning axle back have the same issue? (this is the 3inch can axle back)
I might be way off too any thoughts on what can make noise right under there. I'd put the car in the air, but with the negative temp and snow here in Colorado its not that easy.
Old Feb 9, 2011 | 06:07 AM
Domo's Avatar
try to retighten every bolt when you get a chance.
Old Feb 9, 2011 | 06:42 AM
STlTCHES's Avatar
I'll definitely be giving that a try when i get the chance. Thanks Domo!
Old Feb 9, 2011 | 01:52 PM
indecisive311's Avatar
Scion Noics
The p-tuning guys are on this forum a lot and would be glad to offer advice. PM blownxa and he might have an answer for you.
Old Feb 9, 2011 | 02:55 PM
PTUNING's Avatar
Hello Stitches,
The PTUNING axle-back only replace the rear muffler section. So, if you are hearing noise underneath the arm rest then it could be that when u installed the new axle-back, you may have altered something on the midpipe causing it to hit the undercarriage.
Also, if you wish, please email us an install picture, we may be able to diagnose the problem for you.
Regards,
Mike @ PTUNING
mike@ptuning.com
Old Feb 10, 2011 | 01:17 AM
STlTCHES's Avatar
Thanks for the input Mike when I get the car up in the air I'll snap some pictures get another set of eyes on the issue.
Note to all of P-Tuning: You guys are awesome!
Old Feb 10, 2011 | 02:16 AM
yeldak's Avatar
I had the same issue, its the s-pipe tapping the tranny crossmember..
Old Feb 10, 2011 | 02:41 AM
STlTCHES's Avatar
Did you happen to have a solution for it? Do I need to make an adjustment to the S pipe?
Old Feb 10, 2011 | 07:46 AM
DeAnzaJig's Avatar
whenever i have annoying tapping issues on exhaust/intercooler pipes, i just find the contact spot and wrap it in a bit of heat wrap. fixed all my clings and clangs!
Old Feb 10, 2011 | 11:30 AM
yeldak's Avatar
yessir... not sure what turbo kit you have, I myself have the ZPI. I actually had to take a grinder and shave a notch in the crossmember.
Solowcal_tc1
14
Feb 27, 2024 06:23 PM
carid
Feb 9, 2015 01:49 PM
snappe2
Jan 27, 2015 05:29 PM
DjFrOsT
Dec 13, 2003 04:18 AM
Docofmind
9
Oct 23, 2003 04:08 PM
