Pre-made exhausts with resonator & hi-flow cat?
Good morning everyone
I've just recently started keeping up with the tC's aftermarket again, and have been installing a few new things. Sometime in the soonish future I want to install a catback, however since I also want to go with a header most likely, I want to make sure that I have a hi-flow cat and a resonator so I don't get a ton of rasp. I know a lot of people here have had good luck with having custom exhausts made, so that is definitely a route I will look into. Despite that, getting a pre-made one appeals to be more because it's something that my dad and I could install together (he's almost more excited than I am about installing car mods.)
The thing with a lot of the pre-made catbacks that I've seen is, that most don't come with a resonator and a hi-flow cat. I remember that the Draxas exhaust did, but unfortunately it seems that they are gone now. The only other one that I can think of that does for sure is the CreativeCompacts one (as an option.) Are there any other brands that do? The Dezod exhaust, perhaps? I've done some searching and I couldn't find anything else, but I wouldn't be surprised if there was something that I missed. It doesn't matter if it's a brand that's out now or yet, since it will probably be a little while before I can sneak another car mod past my wife anyways
Thanks!
Thanks!
The only one I can think of as of now is the Dezod street power exhaust:
http://www.dezod.com/pd_street_power...temtc_0506.cfm
I've heard/seen it in person and it seems like a well-made exhaust and it sounds good too. This car didn't have a header tho...
ALL of the name-brand bolt-on exhausts are overpriced and designed for looks and sound, and that means loud without a header. Now replace the most restrictive part of the tC exhaust - the exhaust manifold - with a header and you'll see, or rather you'll hear
, you're going to have to do some custom exhaust work anyway. There's a ton of threads here from folks battling the inherent rasp/drone from header + aftermarket exhaust.
You could go totally custom, buy your muffler, cat, and resonator from a place like summitracing.com and have a local exhaust shop weld it up for you and save hundreds of $$ over a CC or Magnaflow bolt-on system.
I'm going custom myself and going to try something a little different from what I've read here on SL. But for now if you're intent on getting a ready-to-bolt-on header-back with a straight-through muffler, I would recommend precisionmuffler.com. They can weld in a cat, large resonator, and large Magnaflow muffler of your choice and deliver it at a reasonable price.
Hmm I didn't think PrecisionMuffler did cat-backs any longer? Are they just special order now? I'll have to look into that.
Although to be honest, I'm starting to lean towards just not bothering with a header and the negative issues that come with having one (rasp, worrying about CEL's, etc.) I may just get a nice cat-back that sounds good with the stock manifold, and put that header money towards a supercharger (wish me luck with that one lol.)
Yeah, F/I is better way to go if you want good power gains. You only get so much from N/A since no one makes a tuned I/H/E bolt-on system for our car -yet (here's hoping it will happen!)
Have you considered turbo? The S/C will only bring you up to about 184whp so most folks either add header & exhaust and/or buy S/C pulley, increase boost & re-tune on dyno for more power. By that time you've spent as much $$ as you would for ZPI Stage 0 turbo + tuning - not that that's the best turbo available, but you get my drift ...
Also, your exhaust needs simplify. The turbo makes a pretty good muffler itself, all you need is 2.5" downpipe and catback, should sound pretty good.
And turbo is the ultimate bolt-on - think your dad will like that!
xa007xa
Mar 31, 2015 09:24 PM
TheTripleC
Jan 4, 2015 06:46 PM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
Besk_one
26
Nov 19, 2003 09:57 PM
