pullies...a few questions.
Old Mar 6, 2006 | 02:00 AM
Smoses799's Avatar
Default pullies...a few questions.
ive been looking at underdrive pullies and i notice that nonstoptuning (nst) also has alternator and water pump pullies. Does anyone know what the benifits of the water pump pully is? Also, im curious to find out how the alternator pulley increases that alternator output.
Old Mar 6, 2006 | 02:06 AM
WeDriveScions's Avatar
The WaterPump Pulley is significantly lighter... along with the overdriven alternator pulley... which, spins the alternator faster, as the underdrive crank takes power from the other accessories... so you don't have to worry, if you have a large electrical draw on your system.
[table:db2f0fc2e5][mrow:db2f0fc2e5]Crank Pulley[mcol:db2f0fc2e5]Alternator Pulley[mcol:db2f0fc2e5]Water Pulley[mrow:db2f0fc2e5]OEM ~55oz[mcol:db2f0fc2e5]OEM 9.6 oz[mcol:db2f0fc2e5]OEM 13.4 oz[mrow color=red:db2f0fc2e5]NST UNDERDRIVE 20oz[mcol:db2f0fc2e5]NST OVERDRIVE 3oz[mcol:db2f0fc2e5]NST LIGHTWEIGHT 6.3oz[/table:db2f0fc2e5]
There you go!
Old Mar 6, 2006 | 02:20 AM
hPower's Avatar
^^ That is correct. The NST pulleys are truely the way to go. You get a nice amount of weight reduction as well as some underdrive from the crank pulley. Basically the crank pulley will slow down the accessories a little bit so that more power can be sent to the wheels.
The Alternator pulley is designed to spin the alternator faster than normal, this means the alternator will charge at a lower RPM than it would otherwise. Charging the alternator at a lower RPM means more power from the alternator when you are sitting at ilde or at low RPMs.
Old Mar 6, 2006 | 05:54 AM
tCing_U's Avatar
Originally Posted by hPower
^^ The Alternator pulley is designed to spin the alternator faster than normal, this means the alternator will charge at a lower RPM than it would otherwise. Charging the alternator at a lower RPM means more power from the alternator when you are sitting at ilde or at low RPMs.
but will this burn your electrical system in your car (such as radios, ecu, etc.) ???
Old Mar 6, 2006 | 02:58 PM
hPower's Avatar
No it will not! 20% overdrive is within the range of the alternator's ability. Now if it was like 40% or more then you would be concerned.
Old Mar 6, 2006 | 06:15 PM
Smoses799's Avatar
any ideas on the average professional install cost for these pullies?
Old Mar 7, 2006 | 12:53 AM
zettahertz's Avatar
I think installation is about $150
Old Mar 7, 2006 | 12:59 AM
Depends on if you just want crank, or water and alternator as well... I wouldn't run the overdrive alternator without the underdrive crank... as there's no real reason to raise the charge if you have a stock crank...
Check out my NST pulley install thread in the FAQ section and you can give that to the shop if they need any help! LoL
If you get a good shop... It'll take them around 2 hours labor to do all three... which is around 15o or so.
Old Mar 7, 2006 | 05:05 AM
Smoses799's Avatar
okie. i plan on running all three. atm im running a 1800rms(ish) setup, however i plan on adding an additional 1500rms(ish) to it, so ill need the underdrive pully (yea i know ill need to respool/swap alternators at some point)
Luisfc1972
Scion tC 1G Wheel & Tire
10
Oct 23, 2015 05:49 AM
CrowJenkins
Oct 9, 2015 10:47 PM
sccarally
Regional - Lonestar
Sep 27, 2015 09:24 PM
Mjdavis1994
Sep 21, 2015 04:42 AM
iFangy
Aug 13, 2015 05:10 AM
