question bout my megan spipe(downpipe)
ok so i ordered my spipe from wesellcarparts.com and i was wondering do i have to do any mod to it or anythin cuz i been readin that i might to get sum other items so my cel light don't come on i have stock headers and changing out the spipe can sum1 please help me
so from wat i read it will work if u do it the rite way but all these ppl that try it have headers i don't have headers i'm keepyin my stock one and only changin the s pipe would i still need to do all that work
nope, its a straight swap, no anti-fouler needed, and no CEL. i just did mine 2 weeks ago. same downpipe from the same seller.
i had some bit of issues (well, confusion really). so lemme know if you have some ?'s
you should receive 3, (2 thinner ones, 1 thick one), all 3 go on the midpipe side. so it should be:
s-pipe- thin gasket-thick gasket-thin gasket-midpipe.
oh, and i also had issues getting that thick gasket onto the end of the spipe past the flange. haha...my pain is your gain!
^ you've got my setup
It's smart to spray some penetrating oil on the bolts about 10 minutes before you want to take them off. Unclip the O2 sensor at the harness (you'll need a small standard screwdriver to push a piece of the harness down), and take the whole mess out. Spray the O2 sensor threads with lots of penetrating oil. I found the easiest way to get it out was to put the hex part of the O2 sensor in a vice, and turn the s-pipe like a propeller to get it out.
I've yet to install the s-pipe with the SES, but I have had it installed with another exhaust. It doesn't make it raspy, just a little louder. The sound is pretty much the same, just more volume.
well i really not into changin my headers i just wanna changin the piping let sum air out thats it and make sum noise later on i'll change my headers its dat not its a problem the the cel and i don't want that i just got my car and its on 08
Originally Posted by tcbyrc
Why are you changing the exhaust and not the header. you don't gain any power with just the exhaust,maybe 1 or 2 hp and tq.
