Reasons for possible bad MPG
Old Feb 20, 2008 | 10:15 PM
jrodTc's Avatar
Default Reasons for possible bad MPG
I used to be boosted a few months back, but decided I wanted to go back to stock and retain my lovely 23mpg in the city. Well, ever since I put my car back to stock, stock injectors, stock intake...but I notice, i'm only getting 18 or so MPG! I DO still have a 2.5 inch spipe back exhaust on. It has no cats and a Magnaflow muffler. Could my large exhaust be the cause of my 5mpg loss I am seeing in gas mileage? I plan on putting the stock exhaust back on, but havent' had the opportunity. Any ideas?
Old Feb 20, 2008 | 10:21 PM
chrisNOF's Avatar
Default Re: Reasons for possible bad MPG
No cats, thats whats killin your gas miles
Old Feb 20, 2008 | 10:25 PM
jrodTc's Avatar
There is a Cat in the stock exhaust header which is on.
Old Feb 20, 2008 | 11:03 PM
NurSpec's Avatar
Do you have a different ECU, stand alone, or piggy back?
Old Feb 20, 2008 | 11:05 PM
jrodTc's Avatar
No I do not. Completly stock now. the only thing that is not stock, is the midpipe and axel back portion of my exhaust. I was under the impression that that shouldn't cause my decrease in MPG but i'm up for ideas!
Old Feb 21, 2008 | 12:23 AM
BuddhasTC's Avatar
no secondary cat, heavy foot, and the car is still getting used to no more boost
Old Feb 21, 2008 | 07:17 AM
Steventc07's Avatar
bad O2 sensor can do it
Old Feb 21, 2008 | 04:05 PM
Mid_Life_tC-risis's Avatar
Cats -1,2 or none - aren't going to noticeably affect your mileage. If you had a bad O2 you'd have a CEL.
Is your s-pipe 2.5"? If so that's a full 2.5 exhaust, you have less low-end torque than when you were stock and maybe you're gassing it more off the line to compensate.
Otherwise, go easy on the throttle for a while, wait a couple more tank fulls, then see where your at.
Old Feb 23, 2008 | 04:22 AM
cmv138's Avatar
your car hates you for taking away the boost so it's making you pay for it!
Old Feb 23, 2008 | 06:21 AM
07_Tc_blacksandpearl's Avatar
Try resetting your ecu... Just take of the battery negative terminal for a bit and let everything reset. Then let your car relearn the adaptation values for idle and load and see where your at.
Old Feb 25, 2008 | 01:36 AM
Tc4Eva's Avatar
Team ScionTific
Well my .02 did you change back you ecu as well? or did you do that in the process of changing back to stock already?
Old Feb 25, 2008 | 01:36 PM
Crayola_G's Avatar
seriously lol its like pulling aside a star quarter back and be like sir we're sorry we need to remove your apandages, but we'd love you to keep playing. He wont be pleased.
Old Feb 25, 2008 | 01:40 PM
Ace83's Avatar
Ronin Scion
yeah try doing this.. you ecu adapts and alters signal due to boost and piggyback..
Old Feb 25, 2008 | 03:44 PM
tC4me's Avatar
Don't forget to check your tire pressure. Probably isn't costing you 5 mpg but it does make a difference.
Old Feb 25, 2008 | 04:02 PM
Jan06xB's Avatar
The O2 sensor can be working but out of spec and producing a richer than normal mixture causing MPG loss. You could have also lost some compression from wear in the cylinders/rings when you were running boosted. Compression check would be the first thing to do and maybe an exhaust gas check with a CO2 meter and hydrocarbon check. Change the oil in the engine and tranny since they both got beat up when running boosted. Front end alignmant check and tire wear - all that torque may have bent something too. Did you run a lower temp thermostat?
Fisqual
Sep 22, 2015 05:51 AM
mischadoll
Mar 9, 2015 05:48 AM
TCnewguy
Feb 16, 2015 03:50 AM
NewBox06
Feb 3, 2015 04:02 AM
TheTripleC
Jan 4, 2015 06:46 PM
