Removing Belt
Old May 15, 2007 | 07:43 AM
ExEr101's Avatar
Default Removing Belt
How do you remove the belt on the motor it looks like you need a special wrench for the tension pulley.
Old May 15, 2007 | 07:47 AM
Neothin's Avatar
https://www.scionlife.com/forums/viewtopic.php?t=100062
that might help...
Old May 15, 2007 | 08:48 AM
ExEr101's Avatar
I looked at step 7 is it the sloted bolt on the pulley? or the bolt to the right of it?
(Step 7 - Locate the tensioner bolt and use the breaker bar to pull the tensioner assembly toward the front of the car, while pulling off the belt from the crank pulley down below)
Old May 15, 2007 | 10:57 PM
ExEr101's Avatar
Bump
Old May 16, 2007 | 12:57 AM
boostaddict's Avatar
you will see a 19mm bolt looking thing thats on the bracket pull it towards you and hold and slide the belt off that is how you release the tension. those pictures are hard to figure out..your notpulling on a pulley itself theres like an arm with the spot for a socket...you odnt have to remove any pulleys leave the tensioner for last and you slide the belt on while you pull down
Old May 16, 2007 | 05:34 AM
ExEr101's Avatar
thanks for your help boostaddict.
Greg S
Jul 21, 2016 07:28 PM
Rhymenoceros
Scion xD Drivetrain & Power
Jul 2, 2016 10:12 PM
BlackKnight
Sep 15, 2015 06:42 AM
vitkh
Nov 30, 2014 02:27 PM
BlueBox
14
Jan 15, 2004 01:08 PM
