Scion tC 'Chilton' Manual
Old Feb 26, 2010 | 11:13 PM
rougenite's Avatar
Default Scion tC 'Chilton' Manual
Go Google yielded no results. I know there is one around. 'Search' button and 45 mins later, no go.
If you know where I can get it please LMK. Much appreciated
Old Feb 26, 2010 | 11:17 PM
ack154's Avatar
There isn't one to my knowledge... what do you need to know?
(no Hayne's manual either)
Old Feb 26, 2010 | 11:53 PM
rougenite's Avatar
Lol well...everything. The last engine I took apart was a 350 Small block in a 78 K5...Much easier to do, got enough room to sleep next to that thing under the hood...
Im looking for all the specs on torque, clearances, things like that.
Old Feb 27, 2010 | 12:48 AM
yellowxhoodie's Avatar
heres some.
TORQUE SPECIFICATION
Part Tightened ..... ft-lbf
Spark plug x Cylinder head..... 14
Front wheel ..... 76
Engine hanger No. 1 x Cylinder head ..... 28
Engine hanger No. 2 x Cylinder head ..... 28
Radio setting condenser x Cylinder head ..... 7
Water bypass pipe No. 1 x Cylinder block ..... 80 in lbf
Drive shaft bearing bracket x Cylinder block ..... 47
Drive shaft bearing bracket x Stiffening crankcase..... 47
Engine mounting insulator RR x Engine mounting bracket..... 64
Engine mounting insulator FR x Engine mounting bracket FR ..... 38
Engine mounting insulator LH x Engine mounting bracket LH ..... 64
Engine mounting insulator RH x Timing chain cover ..... 38
Engine mounting member x Body ..... 33
Battery carrier x Body ..... 9
Air cleaner case x Body ..... 44 in.lbf
Balanceshaft housing x Stiffening crankcase ..... 1st step 16ft.lbf 2nd turn 90 degrees
Stiffening crankcase x Cylinder block 24
w/ head taper screw plug No. 1 x Cylinder block..... 19
Oil control valve filter x Cylinder block ..... 22
Cylinder block water drain #### x Stiffening crankcase assy ..... 18
Cylinder head x Cylinder block ..... 1st step 58ft.lbf 2nd turn 90 degrees
Camshaft timing oil control valve x Cylinder head..... 80 in.lbf
Camshaft timing gear x Camshaft..... 40
Camshaft timing gear or sprocket x No. 2 Camshaft ..... 40
Camshaft bearing cap No. 1 x Cylinder head ..... 22
Camshaft bearing cap No. 2 x Cylinder head ..... 22
Camshaft bearing cap No. 3 x Cylinder head ..... 80 in.lbf
Oil pump x Stiffening crankcase ..... 14
Chain tensioner plate x Stiffening crankcase ..... 9
Oil pump drive shaft gear x Oil pump ..... 22
Chain vibration damper No. 1 x Cylinder head ..... 80 in.lbf
Chain vibration damper No. 1 x Cylinder block ..... 80 in.lbf
Chain tensioner slipper x Cylinder block ..... 14
Timing chain guide x Crankshaft bearing cap No. 1 ..... 80 in.lbf
Chain tensioner assy No. 1 x Timing chain cover ..... 80 in.lbf
Crankshaft pulley x Crankshaft ..... 133
Oil pan x Stiffening crankcase ..... 80 in.lbf
Oil pan drain plug x Oil pan ..... 30
Water pump assy x Cylinder block ..... 80 in.lbf
Water pump pulley x Water pump assy ..... 19
Crankshaft position sensor x Timing chain cover..... 80 in.lbf
Camshaft position sensor x Cylinder head ..... 80 in.lbf
Oil filter union x Stiffening crankcase ..... 22
Oil filter x Oil filter union ..... 10
Ventilation valve x Cylinder head cover ..... 14
ribbed belt tensioner x Timing chain cover ..... 44
Engine mounting insulator RH x Body ..... 38
Vane pump oil reservoir bracket x Body ..... 69 in. lbf
Return tube x Body ..... 69 in. lbf
Radiator reserve tank assy x Body ..... 44 in.lbf
Engine cover No. 1 x Cylinder head cover ..... 62 in. lbf
Exhaust manifold converter x Cylinder head ..... 27
Exhaust manifold heat insulator No. 1 x Exhaust manifold converter ..... 9 ft.lbf
Manifold stay No. 2 x Exhaust manifold converter ..... 32
Manifold stay No. 2 x Stiffening crankcase ..... 32
Manifold stay x Exhaust manifold converter ..... 32
Manifold stay x Stiffening crankcase ..... 32
Oil level gage guide x Water by−pass pipe No. 1 ..... 80 in.lbf
Drive plate & ring gear (A/T) x Crankshaft ..... 72
Flywheel sub−assy (M/T) x Crankshaft..... 96
Connecting rod cap x Connecting rod ..... 1st step 18ft.lbf 2nd Turn 90 degrees
Crankshaft bearing cap x Cylinder block ...... 1st step 15ft.lbf 2nd 30ft.lbf 3rd turn 90 degrees
SFVTC 08's Avatar
The service manuals are floating around on the web, and they should have most of the info you need, off hand here's what i could find
05 service manual
http://rapidshare.com/files/58650730...op_Manuals.rar
here's a thread with the electrical wiring diagrams
https://www.scionlife.com/forums/scion-tc-1g-ice-interior-1647/scion-tc-electrical-wiring-manuals-05-07-a-73323/
Old Feb 27, 2010 | 03:27 AM
Murphys_Law's Avatar
id like to have a chilton as well, i own one for every car ive ever owned
Old Feb 27, 2010 | 08:00 PM
rougenite's Avatar
WOOT! Thanks for the info! Saved to a word document!
I find it odd that we dont have a manual... sad panda
kleecker
Jan 1, 2015 07:34 PM
baker08tc
Dec 30, 2014 12:02 AM
pro710
Dec 29, 2014 06:52 PM
Pirate183
Nov 29, 2014 07:37 PM
Strader
Oct 1, 2003 03:23 PM
