Shifter Assembly Question
My friend and I were installing my CC short shifter today and it went fairly smoothly. Just one problem, we noticed after we had the assembly back together that the shifter was having trouble with left right movement. Upon further investigation we discovered that on the left side of the assembly behind the spring peice there was a small peice of plastic pertruding out with a small black bushing on it. This peice had snapped off along the install process and was jamed. We were able to get it out and the car seems to shift perfectly. My only concern is not knowing what purpose that "nubbin" served.. We thought it might have been to stablize the shifter or something.. I notice a small amount of left right play in the shifter while in gear but nothing out of the ordinary -- about the same amount as in my buddy's s2k..
This is the nubbin:
Any ideas?
--brian
This is the nubbin:
Any ideas?
--brian
Originally Posted by monkeyMojo
We must be talking about a different peice. The shifter works perfectly.
Kevin
TWM Performance
That makes perfect sense, I did notice that the shifter doesn't spring back to neutral as quickly as it did before and was wondering if this had something to do with it. No, it completely broke off, seemed that while the bushing was thick the actual peice of plastic was very thin so I'm not surprised it snapped off. Do you see any long term ramifications from not having it? I was thinking about drilling a small hole and using a tiny machine bolt to replace it.
Thanks for clearing this up!
Hopr this helps,
Kevin
TWM Performance
bootlgr
Jan 26, 2016 01:22 AM
NonStopTuning
Jun 29, 2015 07:42 PM
