Strup header problem
I just installed my brand new Strup race header and was wondering if anyone had this same problem. It leaks between the S-pipe and header... The S-pipe is stock would buying an aftermarket S-pipe fix the problem? Sorry if this is a retarded question
Originally Posted by KINGxOFxSKA
Retarded questions usually can be answered by using the
Button....
Button....
Button....
Button....Hmmm.... I could've sworn retarded questions get retarded answers.
Jesus Christ answer the damn question or quit wasting bandwidth. The issue could be bolts loose or a damaged header or even a worn gasket. Check all of the items listed above and let me know if its fixed. If it isnt I will work on other possible fixes.
tried everything didnt get a gasket with the headers when i bought it and i bought the headers brand new so there shouldnt be any damages the spring bolts arent loose or anything tried about four times and it still leaks
There has to be one. Go look at your old header at the bottom flange and you should find the factory donut gasket. You might need a flathead screwdriver to pop it off.
DJ_FroZone
25
May 30, 2019 07:17 PM
hotroddelux
Dec 3, 2014 11:33 PM
