tc low idle and shake problem
check the mass air flow sensor, remove it, look at both sensors the two dental floss looking wires down the tube and the amber bulb on the outside, probably dirty. Get yourself some CRC brand MAF sensor cleaner from autozone or oreilly (about $
the mass air flow sensor is right at the air intake box, but sounds like you have replaced it with a cold air intake, chances are if you're using an air filter that is aftermarket and needs to be oiled, that oil will get on the maf and mess up your idle.
also while you're at it, clean your throttle plate and throat. Don't spray the cleaner down the throat always onto a clean lint free rag and then clean. The intake manifold is plastic, and the throttle body cleaner can melt the plastic! But it's safe on a rag.
if your idle doesn't improve after cleaning the maf, then disconnect the battery wait a half hour, reconnect, start the car, do not hit the gas, let it idle for about 5-10min.. without any accessories on, the computer will re-learn the sensors now that it's clean.
, gently spray many times both the dental floss and the amber bulb, let dry, then reinstall/reconnect.
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
cid_mcdp
Jan 5, 2015 02:45 PM
TheTripleC
Jan 4, 2015 06:46 PM
