View Poll Results: Does the Anti-Fouler Worth the trouble?
Yes
81.25%
No
18.75%
Voters: 16. You may not vote on this poll
thee Anti Fouler, does it work??
Old Mar 2, 2009 | 01:13 AM
st432's Avatar
Default thee Anti Fouler, does it work??
So here's the deal.. not to long ago i purchase aftermarket headers.. consequently my my CEL is on.. so my mileage is really hurtin'
i've heard alotta talk about the anti-fouler... does it really help?? are their any side effects??
let me know
-peace
Old Mar 2, 2009 | 01:23 AM
ack154's Avatar
Um.. it's how you get rid of the CEL... I'm not sure why you wouldn't do it.
Old Mar 2, 2009 | 01:29 AM
draxcaliber's Avatar
are you sure the cel code is for the catalytic convertor not being there?
deficient cat does not cause your mpg to go down. it will not effect your performance.
however, if you damaged the primary o2 sensor in the oem header, and you have a CEL for that, then your car will be running safe mode, and that causes your mpg to take a nose dive.
first pull the cel code and make sure that the code is for the lack of a cat, and not a damaged o2 sensor.
now, does an anti-fouler work, if done correctly, it will. i have been running the weapon-r one for about a year and everything works fine.
Old Mar 2, 2009 | 01:31 AM
1AZ's Avatar
1AZ
yes it works.
either buy the one they sell .....
or make your own use two spark plug antifoulers . drill a 1/2 inch hole in one and screw them together.
i made my own it was cheaper
Old Mar 2, 2009 | 01:41 AM
mdaaboul313's Avatar
^ x2
Old Mar 2, 2009 | 03:31 PM
AnyMeans's Avatar
I made my own with 3 and I haven't had a single CEL, other than when my coupler on my intake fell off
Old Mar 2, 2009 | 08:09 PM
engifineer's Avatar
I have heard it work for many, for some they still had issues with the CEL. Moving the O2 bung behind the second cat would be the best way to ensure it never comes back, but if the antifouler works for you, then that is a cheap and quick way to do it.
And as mentioned, the code caused by not running the antifouler has nothing to do with the way the car runs. So if your mileage suddenly got much worse, you may have another issue.
Old Mar 3, 2009 | 01:10 AM
bbsciontc's Avatar
Mine has been going strong for over 2 years now. I would recommend using anti-seize compound on the threads where the o2 sensor and antifouler meets and again where the whole assembly meets the s-pipe. It may help in removal should the fix not work for you.
Old Mar 3, 2009 | 08:18 PM
jwaggz82's Avatar
yup use the anti foulers - i used one long and one short - if there are only short ones, use 3 short.
Old Mar 3, 2009 | 11:42 PM
toyota_scion_tc's Avatar
X2! That is the only way I got rid of my CEL was to have a high flow cat OBDII certified and Carb certified. I relocated the O2 sensor behind the cat and didn't have any more issues.
Old Mar 4, 2009 | 03:15 AM
CSOCSO's Avatar
i just wonder who voted no and WHY?
the question was :
the answer is: yes.. the cheapest and easiest fix what you can have.
ok maybe not the easiest if u have to drill. just buy the L shaped one for 10 dollars.
i have megan racing header and i had to drill my fouler but it wasnt a big deal.
ended up using 3 fouler because cel came back on highway when i used only 2.
if u have cel because of the header. do the fouler trick.. if the cel comes back try to install a third one if its still there after you reset the ecu then relocate the sensor behind the high flow cat.
anti_virus347
May 28, 2015 06:01 AM
anti_virus347
Apr 3, 2015 05:17 PM
Kodokan_4
Oct 29, 2003 05:49 AM
