Is there a difference between turboing a maunal vs automatic
well the auto will have more parasitic loss meaning the same setup on a manual will get more power. and the auto wont be as strong as the manual and would be best to build up the auto some before adding the turbo. hope that helps
as far as the kit is concerned, i would think not. the only difference where the turbo and downpipe are is the ATF lines but i'd hope that these companies are smart enough to set them up around the OEM path and not take a chance of those hitting.
as far as prepping the car, you would want to get a larger ATF cooler and mount it somewhere AWAY from the turbo. right now the lines would be going very near them and that would not be good for your automatic transmission. heat is it's enemy. you can buy transmission coolers from any good performance store.
you may also want to look at a better torque converter if you're into lots of drag racing.... along with a limited slip. I would recommend the Quaife but it's not out yet.
Team No Limitz
put me(automatic) up against a 5 speed turbo xB and we will see who will win...all i can say is i dip off 1 psi in between auto shifts and a 5 speed hits vacuum in between shifts...see ya lata stick...supercharger is a different story though
And as far as the SC being different, are you reffering to a centrifugal unit? If so, they also exhibit lag (not quite as severe as a comparable turbo, but still there). If you are talking about a screw or roots type, then yes, they are more linear in nature.
Team No Limitz
Originally Posted by engifineer
Do you have a stall? If not, you would get raped off the line by a decent 5spd driver (unless you power brake it every time... then say bye bye auto tranny fairly soon) . A good 5 spd driver will shift barely slower than your auto and an auto has a ton of "slip" compared to a 5spd. So stock for stock with nothing but the same turbo kit added I seriously doubt the above. With a good, well built performance auto dropped in yes, but with a stock unit and no high stall a competent 5spd driver should have you. Keep in mind my mention of a well built performance tranny. I have seen some autos that will surprise the hell out of you... but I have also seen the same ones killed by a good driver in a 5spd.
I should have specified that I was talking about a roots which is always boosting in motion
Team No Limitz
Originally Posted by metalranger33
5sp overall is a better setup for the performance orianted. U can do a lot of things with a auto, but put a 5sp vs a auto (both stock) and see who will win
yea well those automatics are not stock they are built like a tank. we're talkin about a tq convertor, trans brake, valve body, trans cooler, limited slip, etc... thats when your transmission will be able to shift faster than a human. but pretty much w/ same setups as long as u can drive a mtx half decent u will pull away from the atx w/ same mods. that goes for u too simplyscion :-P
Team No Limitz
Looks like im gonna hafta line up to 5 speed boosted box and see what happens...Ill make sure to post up a video regardless if I win or loose
now...where to find one in my area
There is no difference between auto and 5-spd turbo kits. They're one size fits all, it's just that the 5-spd can take more abuse. As far as an auto is concern, you don't necessarily need to build it up if your using a conservative amount of boost (~6psi). Just add a tranny cooler and some synthetic fluid, and you should be alright. The auto won't blow off during shifts (it will only blow off when you let off the gas), so it's always boosted.
Team No Limitz
Originally Posted by reagulator
is it true automatics dont "blow off" inbetween shifts? which is good for drag
wastegate opens up. blow off valve opens when the throttlebody is closed. you should use a MBC or EBC to control boost spikes between automatic shifts.
evolving_machine
Oct 21, 2023 01:16 PM
