Tips or Advice on Removing Stock Manifold Studs
2 nut method, works perfect every time. Put one nut on, thread half way down the stud, put a second nut on and tighten them into each other pretty tight using a wrench on each nut, then use a wrench to remove the stud by turning the inner nut counter-clockwise. If you try to use that stupid 6 point on top of the stud, youll just end up stripping it ;)
wow..sounds pretty neat,so i take a (2) nuts what size.....the first one i put on half way but not tight against the block but in the middle,then i take the second one thread that up against that,until tight,then i just use the inner nut to remove the stud,did i understand this right
http://www.dezod.com/files/ExhmanistudDIY.pdf
im going boost,and my stock studs,dont look healthy at all,all rusted,and dont wanna take a chance with the thicker turbo,flange,people i know,told me,you only get like,4 turrns on the stock studs,which sometimes the nuts strip in the process due to trying to tightened,them,so i dont wanna take the chance,rather just have everything,new and fresh
darkshadowofxdeath
12-03-2014 06:59 PM
