Umnitza OFFICAL dyno test run.... ILLUSIVE MOTORSPORTS.com
Ok my car... 05 SW tC... Only mods.... ZPI Exhaust... (argh)
Friday 12/2/05 was day one did 3 runs. First run was stock box... then next to was with the umnitza swapped in with ecu reset.
Day 2 was monday same time of day and as you can see almost exactly same conditions... Now the first run is soppose to be the stock run from the first day... but the gains are different so please refer to the day 1 dyno...
As you can see gain of about 9whp but loss of about 4tq.
I will say this the looks and the sound are off the hook... 4 tq? well I dont notice a difference... I do notice the car gets up and goes a bit more... I chirp third easier and lower rpms now.
Thanks to Matt at Umnitza for letting me be the local tester.
with all due respect to the modacar dyno, I'm still not clear why the intake shows such a weird A/F reading.
But it does validate a lot - it makes power, it makes it after the ECU adapts.
But the drop in torque, not on the last run or the first, but the middle is somewhat disconcerting.
From 5.5k to the 6.25k redline the Umnitza makes more.
Is that a fair assesment?
Seriously, have i totally misread these.
For 80% of the important rpms you make a lose of not only HP but huge amounts of torque. Even when you adjust the top one to match the second one it's still more, until the last 700rpms at which point it gains. By that point the guy with the stock box is half a car length ahead and already in the next gear.
Yah, the car is running WAY to lean and is starving for fuel. Expect a cat failure down the road and possibly other issues related to running on the lean side.
I'd recommend replacing it with the stock box and get your torque back! Heck, get your HP back too... because stock box is making more HP where you use it most anyways.
Hydryman
Feb 23, 2016 03:35 PM
marsman328
Regional - Pacific Mid
Jul 28, 2015 09:43 PM
umnitza
Jul 25, 2015 07:54 PM
