under drive pullies(udp)
Seven City Scions
All this talk over intakes and headers is getting old. when are some compnaies going to come out with lightened UDP. i had one on my old car and it was awesome. it freed up so much power from the engine. btw the udp is a lightened crank pully.
i hear alot of people talking about these but have never actually had them on one of my cars.... how much of a difference does it make (hp wise), and is it safe for your engine/tranny
Seven City Scions
Originally Posted by IndigoDreams
doesnt free up very much power
This is a cry out to a machine shop or some aftermarket company...........make the udp for the tC!!!!!
Crank pully is usually a bad idea,...the Alternator pulleys and the Power Steering ones worked well for my h22 accord. But, you shouldnt throw on a lightened crank pulley because it could mess up your crank over time....but i guess being this careful is just me, everyone else seems to think that im crazy with the comments I make.
Originally Posted by aarontrini85
if i got a lighter alternator pully wouldnt that make more power to prevent my lights from flashing when my sub hits?
I should also note that if you are talking the engine damper this is more then a pulley: it removes the vibration from the engine. A near crazy idea to remove this. As it directly effects the longevity of the engine, if not why would the factory, you know the guys that give you a warranty, go through all the trouble of making a heavy three piece damper if it was NOT needed? Simple it is needed especially with a steel crank which I assume the tC has. As steel tends to ring more then a cast crank. Also longer stroke cranks ala tC also tend to ring more. Basically meaning only a cringing newbie with no knowledge of fundamental engine dynamics would ever contemplating bolting on a light weight solid aluminum damper. THIS WILL VOID YOUR WARRANTY PERIOD.
http://dinancars.com/whitepapersFile.asp?ID=5
Fact: the factory spends big $$$ on each and every engine to make and install harmonic dampers.
Fact: MPG and HP would go up if the factory just milled a cheap aluminum pulley.
Fact: no factory does it. Why?
OK break-up into small grounps and discuss amoung yourselves.
Seven City Scions
[quote="oldman"]Basically meaning only a cringing newbie with no knowledge of fundamental engine dynamics would ever contemplating bolting on a light weight solid aluminum damper. THIS WILL VOID YOUR WARRANTY PERIOD.[quote/]
guess im a "cringing idiot with no knowledge".
