Want to be smooth in the 14 sec Naturally Aspirted
Hi
I've a 2005 Scion TC
with K&N typhoon , DC headers, tri phase, Agency Power Crank Pulley + DC strutbar
I'm looking for more info to go for more HP but Naturally aspirated.
any suggestions?
thanks in advance
any suggestions?
thanks in advance
OK I looked up the tri-phase... I don't know what to say. I don't really understand how it works, and I don't know of anyone else who has bought it.
First off, do you have a manual or and automatic? A stock manual tC will have around 140whp (wheel horsepower) and the auto will have around 120whp. I'm not sure if you are talking about wheel horsepower or crank horsepower in your projected numbers...
The K&N Cold Air Intake produced 3whp and 3wtq as shown here https://www.scionlife.com/forums/vie...ht=intake+test
Your DC Sports Header produces 7whp and 5wtq as shown here https://www.scionlife.com/forums/vie...ht=header+test
So not including the "tri-phase", you are looking at having about 151whp.
There are two types of pulleys, lightweight pulleys and lightweight underdrive pulleys. ZPI makes a lightweight stock sized pulley and NST makes the underdrive pulley. Underdrive pulleys send less power to accessories and more power to the wheels, so you will see more power with an underdrive pulley. NST also makes overdrive alternator pulleys to compensate for the lost power to the accessories and lightweight water pump pulleys. Check out https://www.scionlife.com/forums/vie...ghlight=pulley
With intake, header, full exhaust, and pulley, you should be able to make it into the 14's with a manual... If you have an auto, then it will take alot more work to get there.
The point to all of this is, manufacturers will make claims that are not always dyno proven, so some numbers are vaulted. If you do some searching around on this website, you can find dyno charts for just about every part available for our car. Next time, do some searching and you will find what you are looking for and avoid getting flamed by some of the members here.
What is the tri Phase?
Like TTURedRaider311 said, unfortunatley you arent making anywhere near the power you think you are. You might be making that much crank horsepower, but its HIGHLY doubtful. The supercharger is forced induction and is only running about 220 crank HP. So to get 190 crank HP out of intake header and tri phase (whatever it is), I dont think will be happening.
Have fun on the endeavor of modding.
Hi
Maybe you're right but
here are the sites on the internet that I've visited to get those info
I will apreciate to get your reaction/opinion of what you think about it after chec
king those sites
thanks in advance
Headers
http://www.raceinspired.com/ps-849-4...c-2005-up.aspx
http://www.racerwheel.com/d42-shc4402.html
Cold air intake
http://www.hopupracing.com/kncoairinsct.html
Tri-phase
http://www.nextlevelracing.com/Triphase.htm
king those sites
thanks in advance
Headers
Cold air intake
Tri-phase
I've seen the numbers you quoted before, but like I said above, some of those numbers may not be dyno proven.
I see in your sig you want to hit the 14's... You are well on your way to that, I would add a full exhaust (ZPI, Draxas (my personal favorite), Creative Compacts, etc.) and a lightweight or underdrive crank pulley (ZPI, NST, etc.) The search button on this website is your best friend, there are many threads talking about hitting the 14's naturally aspirated, you should check them out to get some advice. Keep in mind, it is easier on everyone, including yourself, if you search for the information you want first instead of asking a question. Most of the members on here probably know the answer to your question, but few have the time to explain in detail.
The numbers you see on those sites are generalizations and are most probably overrated... to say the least....
I sort of see the point to the whole TRIphase thing... but would rather go with a Emanage or something that allows real tuning control...
You most definately are not running that much to the wheels.... the stock tC runs like 135 to the wheels, plus around 5-8 with an intake, maybe 13 with a header/intake and if you push it with a good tune - 10 more hp by tuning it... you're most likely pushing around 155-160 at the wheels and possibly up to 190 or so at the crank... if it's tuned really well which I couldn't think that you could do taking into account mods and a general tuning device like the "Tri-Phase".
First and foremost, you need to educate yourself about your car as much as possible. Thats where you need to start.
After that, take a lond hard look at what you want to achieve vs. what you want to spend. Then consider how your mean to reaching your goal may or may not void your warrenty. Risk assessment ;)
Then, plan out how you're going to do this with mods. Bolt on or custom? When you think you've found parts you want, you need to educate yourself on what they do, how they do it, and wether or not they REALLY do what they claim they do. Chances are, someone here has been there, done that, and you could save yourself both money and hard lessons learned by educating yourself on said products.
Scionlife really is the Scion's foremost community for knowledge. Use this forum as a tool to help you reach your desired results.
Finally, do not believe everything you read. Especially from someone making a claim without supporting evidence. Like any other market, people sell products and services that result in no gain and money lost. IMO, this Tri-phase appears to be just that. A little snake oil for the tuner-noob if you will. There are no magic switches or amazing fuel additives bla bla bla, and you'll learn all about this stuff the more you read and learn.
Ignorance causes the most problems.
Good luck with your ride and tuning and welcome to Scionlife
The numbers are dyno proven
to be false. You will not get 10hp from an intake, you won't get too terribly much from an aftermarket header, and you definitly will not see any kind of gains from something like "tri phase" Did you order a Turbonator too? :p
In order to beat an RSX S in the quarter mile as an auto, you were likely racing someone who has never been to the track and is likely still learning to drive and doesn't know how to shift.
No way you smoked a decently driven RSX-S.... They are much lighter, much more powerful and with the 6 speed, a tight little machine... I have a co-worker who races his and can push 14.7-15.0 with just CAI and DC Header over and over again.
AS an AUTO.... There are tC's with EManage and all your little mods that can't break 15 yet....
You're going to hit a wall with the serious guys around here.... me included, who've studied and put time into understanding the tC's setup.... You can't just take the blue pill and get what you want to get.
All your little box does is change mixture and timing, to DEFAULT and AGRESSIVE tunes, based on a BASELINE dynoed car. It's super general, and not suggested for anyone who really loves their engine or its longevity. An Emanage can adjust the same settings, but tailored to your engine, your bolt ons, and your fuel.
Playing with fire and going cheap tends to end up as "Boom"
Andreas24
Sep 15, 2015 02:10 PM
