weird engine noise
so latley, my car has been sounding like its s/ced. kind of a whine. it occurs in the lower rpms. and i have no engine mods but the trd exhaust. any ideas? anything to worry about?
umm check your ground wire kit, and check the ground to your subs I know that bad grounds with amplifiers can make a whine, my old hatchback had that for like three days before I finally figured it was my amp ground... next thing is how long has your drop in filter been in??? If its relatively new when air masses our MAF sensor it couses a whistle and if you just put that filter in, you just started getting increased air flow and that MAF whistle is probably more notiecable... Other than that not a clue in the world... hope you figure it out
Are you talking about the turbo-like whistle from giving throttle while the engine is under a load? That's the sound of air being rushed past the throttle plate.
Not sure what it could be if you're talking about something else.
https://www.scionlife.com/forums/vie...hlight=whistle
