What brake Fluid?
Old Apr 24, 2007 | 10:36 PM
kyle1745's Avatar
Default What brake Fluid?
What brake fluid does everyone recommend for track days and autox?
I have been looking into: Motul 5.1 which seems to be a DOT4 fluid and can still be driven on the street without harming the seals and or needing to bled all the time.
Thoughts? what do you run?
After larger tires, and better pads im sure my fluid and lines need to go... :-)
Old Apr 24, 2007 | 11:46 PM
2fast4you's Avatar
Team ScionTific
I use Ate (Ah-Tay) Super Blue in my car, it's the same as Ate TYP 200 but with a dark blue dye. They're boiling points are between Motul RBF 600 and Motul 5.1. Either fluid will do fine for AutoX and daily driving.
Old Apr 24, 2007 | 11:47 PM
Dr_Isotope's Avatar
We run Valvoline SynPower in the race cars, and the brakes on those get a whole lot more work out than any street car on an Auto-X course.
Old Apr 24, 2007 | 11:56 PM
kyle1745's Avatar
Ya I can say the stock stuff can not hang with the track days. Its time to change it anyways. I am trying to see if I can get some speed bleeders for this car first. :-)
Thanks for the replies any others?
Old Apr 25, 2007 | 12:06 AM
Dr_Isotope's Avatar
You can get the speedbleeders from RacerPartsWholesale, 7mm x1.00 - 30, speedbleeder part #SB7100. My full set was ~$37 shipped.
Old Apr 25, 2007 | 12:11 AM
kyle1745's Avatar
Same part for all 4 wheels? Thanks for the info!
Old Apr 25, 2007 | 12:13 AM
Bsmntcuts's Avatar
ATE superblue. it is easier to flush too, due to the different color than stock
Old Apr 25, 2007 | 01:46 AM
Spect2K3's Avatar
The Motul 5.1 is not a DOT4, it is a DOT5.1
This is not the same thing as a DOT5. It has some characteristics of a DOT4 and some of a DOT5. You can use it in the tC although it is only really recommended for track use because you will have to bleed your lines frequently as it will absorb water like no tomorrow.
The motul rbf 600 is ideal for track use. Thats what I would buy if I were tracking the car.
Valvoline Synpower DOT4 is a great brake fluid for us non-trackers.
Old Apr 25, 2007 | 01:47 AM
Spect2K3's Avatar
Read through this thread. I got this information from these 2 guys. They are both VERY knowledgable. TheInstigator works for stoptech (take his word as gospel):
https://www.scionlife.com/forums/vie...r=asc&&start=0
Old Apr 25, 2007 | 02:16 AM
2fast4you's Avatar
Team ScionTific
5.1 is fine for solo events (HDPE & AutoX), and it's used with a lot of success. If kyle1745 was lapping the car regularly he might need DOT4, and I highly recommend it anyway, but he's not going to run into issues as long as he changes the fluid regularly.
And now, the obligatory StopTech link :
http://www.stoptech.com/tech_info/wp...fluid_1a.shtml
Old Apr 25, 2007 | 06:23 AM
tC9o9's Avatar
we are running motul brake fluid in the tC race car.
so far its been working out great.
Old Apr 25, 2007 | 11:16 PM
Spect2K3's Avatar
^^which motul fluid? DOT 5.1? RBF600?
Old Apr 25, 2007 | 11:39 PM
tC9o9's Avatar
RBF600, my bad for not including that earlier.
gqdabien
Oct 8, 2015 05:36 PM
olyellr
Sep 28, 2015 10:32 PM
Klashan
Sep 24, 2015 12:39 PM
DannyBoy65
Sep 21, 2015 06:23 PM
Subaru86
Scion FR-S Aero & Exterior
Sep 14, 2015 12:39 PM
