What does everyone think of Competition Clutches?
Hi guys,
I'm an xA owner but there are a million more of you than us, so here I am. What does everyone think of Competition Clutches? I'm looking at getting one as I want to replace my OEM clutch? Specifically I'm looking for quality and longevity, as I won't be putting out more than stock power on it. I'd appreciate any input. Thanks!
my tC was stock i put in a stage 2 clutch (disc type) and the 12lb flywheel and it was awesome. noticeable difference over stock, i also had a stage 1 clutch before then) im a CC customer for life. plus their customer service is awesome
I'm turbo'd with a Stage4 and I also have their 9lb flywheel.
So far I'm loving the setup. My only complaint is that the 9lb wheel isn't very practical - it makes a ton of noise when decelerating.
Originally Posted by BeQuietAndDrive
Hi guys,
Stage 1 if your looking for a cheap OEM
http://www.dezod.com/pd_competition_...utch_kittc.cfm
In stock
Very good info. I was told it was the lightweight flywheel.
Any idea why it stops after certain rpms? For instance, in 5th gear deceleration, it stops around 2500-3000rpm or so.
Please at least explain why?
That's not to say that they don't make clutches that work. I just think I can spend my time and money else where...
We actually get our clutches custom spec'd now. which has worked out alot better than buying from anyone else because they are designed with a specific application in mind.
I'm not saying one way or another, but you should probably provide more input than just saying you have dealt with cars that had them.
Did the clutches chatter, slip, engage poorly, fall apart, etc?
Well I got my tranny rebuilt in June and while the tranny was out the tech had me look at the clutch. The center rotational springs had rolled the metal case back far enough that the springs were falling out. The surface material was fine and I liked the pedal action of the clutch but it was no way desighed to be a stage 4 clutch. I'm running 14 psi at altitude which is about 310 WHP corrected......
marsman328
Regional - Pacific Mid
Jul 28, 2015 09:43 PM
