WHAT WILL A TC RUN IN THE 1/4 MILE?????
It's hard to run good times on a stock tC...the car runs 15.7 bone stock...but that is with a professional driver...on stock tired it's hard as hell to run that time. Last time I went to the track the best I could run was a 16.2 I'm all stock except headers and exhaust...I couldn't get traction for sh*t..I spun out through 1st and 2nd and a little in third before finally catching traction...and that was with a good burnout.
Did you drop tire pressure too?
You don't need to do a good burn out with radials.. Just a quick spin to get any rocks and dirt off the tread. I haven't been to the track in a while but when i was stock i ran a 15.7 with the spare in the hatch and a half a tank of gas.. Also ride the clutch a little out of the hole, that will help you not breaking the tires loose.
Road & Track tested a stock Tc with a manual transmission in February of 2005, their best time was 15.6 seconds @ 89.9 mph. Even $1000.00 worth of I/E/H won't get you into the 14s. If you want better times for less, buy these:
http://www.mickeythompsontires.com/s...agSportCompact
and run the fronts @ 20 psi!
I tried launching at 3,000 and at 2500RPM'S which is what everyone on here told me would be best for stock tires...and those were the results.
People should have more then minimal amount of skill and knowledge before taking a car to a track and wondering why they ran such crappy times. First understand the basics of drag racing on a track. Racing on track and street is much different.
It's all practice, thats all.. The more practice the better you get. But to answere your first ? The tC stock should do a 15.6 to 15.7 on a good run and if you run it with little gas and no spare tire you will drop a few tenths.
