WHAT WILL A TC RUN IN THE 1/4 MILE?????
Old Aug 27, 2007 | 07:11 PM
  #41
engifineer's Avatar
Thanks TRD springs and rear sway and the hot-chicks front strut tie Does pretty well on the autox track considering I am running all season daily driver tires. Alignment work and a separate set of rims with some sticky tires is next!
Old Aug 27, 2007 | 07:55 PM
  #42
flint_08's Avatar
I would say that 15.7 is very achievable in this car. I am not expert, but I had a 99 Civic LX before my Si, which had the D16Y7 in it. Stock time for it was 17.1 I believe, which was posted somewhere on line. I was able to run 16.6s all night long with a CAI on all season tires.
Old Aug 27, 2007 | 08:39 PM
  #43
Bozuzu's Avatar
flint, if you read the entire thread you'd see I cited a real road test, page one somewhere
Old Aug 27, 2007 | 11:12 PM
  #44
Matt_Burgess's Avatar
Engifineer, does the front strut tie bar help in the tC? I know your into auto cross and all, so i figure you would know. Alot of people say they can't feel any differance and that it doesn't help in the tC. I have the ingalls rear strut brace and it did help out. More of a solid feel and it got rid of my hatch rattle..
Old Aug 27, 2007 | 11:49 PM
  #45
Menace's Avatar
Originally Posted by SickleCell
Originally Posted by Menace
There are people running very low 15s with just I/H/E. It all depends on the driver. Also, switch out the stockies for almost any other tire in the over $80+/tire range and you will have a lot more traction. Switching to 225 is also recommended as deflating your tires to somewhere between 20-25psi. You will see improvement in time just from these simple adjustments.
I thought deflating a street tire is pointless. It's not a drag radial that crinkles. The sidewalls are too small. All lowering tire pressure does is give you a bigger foot print....which may help a little at launch..... but cause more friction the remaining 1320 feet.
It depends on what tire you use but generally speaking you dont want to be at over 30psi, it decreases your traction but gives you more fuel economy. Deflate the tires a bit to increase traction, just make sure you don't over do it. Also, if you are serious about drag, eliminate all the weight you can. While the spare tire, tools, jack, full tank of gas, etc may not sound like much, when they are all removed and you only have 1/4 gas tank, the .1 sec difference may mean the difference between you and the other guy.
Old Aug 28, 2007 | 02:17 PM
  #46
SandMPerformance's Avatar
the trd strut brace feels great after install. they do help, i had bars in my old lancer.
as for the time quote, i misquoted. the fastest time in my boys tC was a 15.3
Old Aug 28, 2007 | 02:27 PM
  #47
Bozuzu's Avatar
burgess that's funny your ingalls rear bar fixed your hatch rattle, that's what started mine!
Old Aug 28, 2007 | 06:14 PM
  #48
engifineer's Avatar
Thats because it did nothing to prevent your hatch rattle, it was a coincidence (taking the rear apart as well) in either case most likely. I have seen one person (on ystc) that tore into the car and found the cause of the hatch rattle (at least the common cause, not loose trim)... back in 2005. It is a poorly made spot weld. The only way to fix involves completely removing the glass. A brace will do nothing for it.
Matt,
I bought my car with the strut brace, but after driving a tC (test drive) without one I could tell little difference really. If you already have springs, sways(s) and good tires, the strut brace would be the next thing to do, but expect the smallest results.
Tires, springs and sway(s) will by far produce the largest result
Old Aug 28, 2007 | 07:13 PM
  #49
ahh, the infamous hatch rattle... i remember at ATL toyota when we first got one of those cars.... ahh, the memories
Old Aug 28, 2007 | 07:49 PM
  #50
crackl0vesyou's Avatar
with slicks or drag radials i would run atleast 14.3 i ran 15.1 with my setup at 94 mph i just have bad tires my boy ran 14.3 on drag radials on his car ( not a tc ) and trapped 94 mph
Old Aug 28, 2007 | 11:00 PM
  #51
I should correct myself it was more like a creeking sound. I use to hear it when pulling in my driveway on an angle but after the rear strut brace it went away. I also put 1/8 rubber under the rear 2 legs of the brace before i bolted them down too. I'm not big on metal to metal aspecially when it comes to a brace like the ingalls thats why i did that with the rubber to stop any extra creeking noises..
Old Aug 29, 2007 | 12:22 AM
  #52
apautogarage's Avatar
I have I/H/E and some Kumho's on 28psi and I ran a 15.1 at the track. First run was 15.4 and second was 15.1!
Old Aug 29, 2007 | 01:43 AM
  #53
Menace's Avatar
^^Nice, try 23-25psi. What I/H/E do you have?
Old Aug 29, 2007 | 02:00 AM
  #54
parkw06tc's Avatar
i got an or tc, all i got is a CAI and axle back Borla, and i ran a 10.35,. . . . . . . . . . . . . . . .in an 1/8th mile. It was still cool though figuring my first time down the same track was 10.73. i improved by alot.
  #55
parkw06tc's Avatar
Old Aug 29, 2007 | 04:20 AM
  #56
Bozuzu's Avatar
ap you ran a 15.1 because of those sexy fine wheels of yours!!
Old Sep 3, 2007 | 02:44 AM
  #57
chazm's Avatar
Pretty much.....you'll see your 60ft increase ever so slightly and your ET decrease ever so slightly
nightfox915
Apr 17, 2015 07:06 PM
mischadoll
Mar 9, 2015 05:48 AM
UltraCronic
Feb 4, 2015 06:58 AM
ndillon
Jan 26, 2015 04:28 PM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
