Where do I hook up a Fuel Sender for a Fuel Pressure gauge
Old Jul 29, 2007 | 03:31 PM
SickleCell's Avatar
Default Where do I hook up a Fuel Sender for a Fuel Pressure gauge
I found a digital pressure gauge and it has a sending unit, but I do not know where I can hook up the sending unit.
Pics would help most!
Old Feb 22, 2008 | 03:03 PM
ippskidder's Avatar
1UP Crew
Someone help us, LMAO.
Old Feb 22, 2008 | 03:08 PM
SickleCell's Avatar
Tap the fuel rail. I ran a return style line into a wet kit and attached the gauge to a gauge adapter. Problem solved.
Old Feb 22, 2008 | 03:19 PM
ippskidder's Avatar
1UP Crew
Right now I have a stock fuel. Where exactly would I tap it? or would I have to get something welded onto the fuel rail? I'm a little lost =(
and what exactly is a gauge adapter?
Old Feb 22, 2008 | 08:13 PM
SickleCell's Avatar
Tap the other end of it. Since you aren't on spray or anything, you can have it setup where the fuel sender gauge can screw in where you tapped it.
I recommend having someone that knows what they are doing to do it for you.
Old Feb 22, 2008 | 08:19 PM
ippskidder's Avatar
1UP Crew
Good recommendation, lol.
Hmmm... I wonder how much it would cost to get a return fuel system. So i'm thinking a fuel rail, upgraded lines, walbro fuel pump.
Old Feb 23, 2008 | 12:25 AM
SickleCell's Avatar
Do you feel that you need it?
Old Feb 24, 2008 | 05:27 AM
Scoobasteve4132's Avatar
watching for info on return set up!
Old Feb 24, 2008 | 06:08 PM
ippskidder's Avatar
1UP Crew
I'll be sleeving my engine soon. So I know i'll have to upgrade the fuel system. ^^
Old Feb 24, 2008 | 11:55 PM
deathbyc4's Avatar
if you're upgrading the fuel system, then set it up to return fuel back to the tank so that you can get an aeromotive regulator (which then you will have to block off the regulator in the tank) and screw in the sender into the the new regulator. the expensive way to do it but would be the best if you are getting bigger injectors later. or find a t connector with an 1/8th NPT female to two barb fittings and stick it between the fuel line and the fuel rail where the line is rubber.
Old Feb 25, 2008 | 12:09 AM
SickleCell's Avatar
If you are doing a fuel system upgrade... tapping the rail and hooking up a fuel pressure sensor is going to be the easy part of that setup lol.
Old Feb 25, 2008 | 05:49 AM
deathbyc4's Avatar
http://www.jegs.com/p/Mr.+Gasket/746566/10002/-1/10019
just get one of these that will fit the fuel line. snip, clip, screw, done.
Old Feb 25, 2008 | 10:23 AM
SickleCell's Avatar
you want to be careful with that. Most of the fuel line in our car runs through metal and is covered in hose. By snipping any part of the line, you won't be able to return it back to stock. If you get a bad seal, you may end up losing fuel pressure. Fuel leak would also suck. If none of that bothers you, go for it! lol.
Old Feb 25, 2008 | 10:49 PM
deathbyc4's Avatar
that's up to the user. i have a return setup
Old Feb 26, 2008 | 02:17 AM
xezerax's Avatar
how long have you been running this setup? no leaks or problems?
Old Feb 27, 2008 | 02:28 AM
soros151's Avatar
Looks like a good option to me. How about the fuel filter of the tC? Run a line long enough for the gauge to be visible,, but short enough not to drop the pressure.
Old Feb 27, 2008 | 04:58 AM
ippskidder's Avatar
1UP Crew
Without tapping the fuel rail. Is there a place where the fuel line is just rubber, and doesn't have metal piping on the inside? so I can use this barb fitting, and finally using my fuel pressure gauge, lol.
k1114
43
Mar 1, 2023 03:08 AM
my06tc
Jun 25, 2015 12:18 AM
eric_m
79
Mar 17, 2013 12:21 AM
mattjk
121
Dec 22, 2004 10:49 AM
eric_m
Oct 1, 2003 03:52 PM
