2AZFE Fuel Rail //Dezod Motorsports//
Old Feb 4, 2010 | 02:32 PM
  #61
DezodDon's Avatar
Originally Posted by johnhawkins
Thanks Crush lol - My Fuel return system is almost complete. I am using the OEM feed line and was planning on using the OEM rail as well. My intank setup is already complete and re-installed consisting of Walbro 255lph pump, PTuning FPR Plug, and custom 3/8" return line. So depending on how compatable this rail would be to convert over to my setup, I was contemplating on possibly getting this.
This should work. You can use the rail separate of in the entire kit. I just recommend using -8an boss o-ring male to -6an male fittings on the return so the fittings clear the cylinder head. Thanks to the way toyota cast the cylinder head it's a tight fit back there. Or you could grind a little of it off as it isn't a critical area.
Originally Posted by t_urbo_C_harged
very nice don! Looking forward to seeing it!
Thanks
Originally Posted by crush02342002
so its entirely plug and play....
You got it. I don't like the idea of having to modify parts like this because of the potential for end user error. If there is a problem you could have quite the safety problem. Ours conforms the NHRA rules regarding fuel systems and lines. I'd rather not take a chance.
Originally Posted by scikotictc232
nice to see dezod steppin it up
We try. These things take time. I am from the breed, do it right, do it once.
Originally Posted by RusWolf
how does your fuel return system compares to ptunings Don ?
This is not meant to be a comparison thread and I don't want to relive some of those train wreck threads so when we do release this for sale I will leave all the information on the site and here on SL and the people can make that call
Old Feb 4, 2010 | 06:53 PM
  #62
paul_dezod's Avatar
Scionetics
KAD
Indeed.
Old Feb 4, 2010 | 09:22 PM
  #63
RusWolf's Avatar
2 Don: I see, well i was asking simply because i have ptuning fuel system, but i'll wait for the info.
Old Feb 4, 2010 | 09:27 PM
  #64
DezodDon's Avatar
Understandable, I just don't want to make claims and have the thread turn into a ____storm Nothing personal
Old Feb 4, 2010 | 09:35 PM
  #65
Hix's Avatar
Hix
You know I have a bunch o' Dezod stuff in my car and was debating on the PTuning rail since I wanted to keep everything similar instead of random brand names all over the car so you can deff count me in for atleast 1.
Old Feb 4, 2010 | 11:11 PM
  #66
t_urbo_C_harged's Avatar
I'm interested as I will be eventually pricing out making my own fuel setup. I may have to add on to yours, if I choose to go with yours, as I want enough supply to do e85 if I wanted to. Plus I LOVE overkill lol.
Old Feb 5, 2010 | 03:02 AM
  #67
SoulXquisite's Avatar
holy crap these things look sick. would they work on S/C setup. checked out the website, looks like they handle N/A setup. so yes right?
Old Feb 5, 2010 | 07:32 PM
  #68
DezodDon's Avatar
Yes this will work with any setup imagineable.
Old Feb 8, 2010 | 06:12 PM
  #69
paul_dezod's Avatar
Scionetics
KAD
Sorry for my absence. I am back now to work. The rail will work N/A, S/C or Turbo.....So please ask away for Q's
Old Feb 8, 2010 | 06:26 PM
  #70
mospeedtc's Avatar
I may wait a bit.... gonna do E85 so its either this or ptunings.....
Any idea on when you will release the return system info/pricing, looking to buy in about a week
Old Feb 8, 2010 | 08:05 PM
  #71
DezodDon's Avatar
I want to clarify this post so that there is no confusion.
If you want to run our fuel rail there is NO grinding necessary to use it with a 180 fitting. This is how our fuel rail and our complete fuel system is run. We did not grind anything. I made this statement for the simple explanation for those that want to do something different.
Our fuel system requires NO grinding and is as plug and play as it gets.
No cutting your fuel feed line is required.
No using your stock fuel feed line as a return line
No modifying your stock sending unit, we did all the work for you
We supply new OEM quality delrin spacers, which is what the OEM is made out of as phenolic is a fiber/paper base material impregnated with resin. Not what Toyota uses.
Look for it soon at a great price as well
Old Feb 9, 2010 | 05:19 PM
  #72
paul_dezod's Avatar
Scionetics
KAD
Stick around, we are just waiting on our black fittings to come in.
It will be worth the wait.
Our rail is E85 friendly due to the Anodization chosen. Make sure it's type II
Old Feb 9, 2010 | 05:20 PM
  #73
paul_dezod's Avatar
Scionetics
KAD
Correct, our test vehicle was not grounded down or heavily modified in any way, shape or form to run this system. All work done was 100% reversible back to stock with ease.
Old Feb 10, 2010 | 02:30 PM
  #74
paul_dezod's Avatar
Scionetics
KAD
Anymore questions? I have answered a few emails and PMs about this unit and I think we covered all of the major bases. Just to recap:
1) Rail will fit stock or modified tC
2) Will fit N/A, S/C and Turbo tCs
3) E85 compatible
4) Meth compatible
5) No cutting or grinding of head to use rail for return system
6) Return portion will be released next week (it's done here from development; waiting on some black fittings to arrive, which should have been here already!)
7) Conforms to NHRA standards
No cutting of factory feed line at tank
9) No buying new parts when converting back to stock
Old Feb 10, 2010 | 03:13 PM
  #75
Hix's Avatar
Hix
Originally Posted by paul_dezod
3) E85 compatible
8. No cutting of factory feed line at tank
This... Me wants one nows!
Old Feb 11, 2010 | 04:29 PM
  #76
paul_dezod's Avatar
Scionetics
KAD
Yep yep! Had a few people order these rails already.
Old Feb 23, 2010 | 05:51 PM
  #77
paul_dezod's Avatar
Scionetics
KAD
In for Friday!
Old Feb 23, 2010 | 07:20 PM
  #78
brett561tc's Avatar
i know who already ordered the return fuel setup and is getting the first one out the door.
Old Feb 23, 2010 | 09:12 PM
  #79
paul_dezod's Avatar
Scionetics
KAD
Oh jeahz?!?!?
Old Feb 23, 2010 | 10:09 PM
  #80
Hix's Avatar
Hix
Can I preorder a return + 850s now :D
