3" Exhaust = Power Loss and Lightened Flywheel = Waste
I'm getting Dezod's S1 kit and I was searching on the 3" exhausts and saw that some people said that you can lose power due to less backpressure, is that true? Because I ordered ZPI's 3" Header-Back Exhaust System and I'm thinking about cancelling the order if that's the case.
And also, I ordered the Fidanza Lightweight Flywheel and I was reading on how it messes up your launch a lot and makes your engine unbalanced. Again, if that's the case, I might cancel my order. But, I do like the sound of better acceleration and less throttle delay.
So, I'm confused between the two issues. Can anyone help me out here?
did you order a aftermarket clutch with your flywheel?? i dont think its a waste you just have to adjust to the different launch.........that OEM flywheel weighs a TON! I plan on getting a lighten flywheel later down the road.....
Originally Posted by Whocares05050
if you want to hit your goal of 450WHP, then keep the exhaust
you gonna install that yourself?? feaking labor on clutch/flywheel seems more than the S/C labor....
A lighter flywheel will make you have to compensate during launch, but you should easilly be able to by revving higher on launch. We normally launch so low you have plenty of room to do that. People running them love the effect and say that you can relearn launch pretty easilly.
If you are doing more than straight line running you will like the effect even more, since rev matching will be easier due to a quicker throttle response (the "delay" people complain about is mostly due to a heavy flywheel and is nearly eliminated with a lighter one if you read posts from those running one). I would keep the flywheel.
As far as balance, the flywheel doesnt balance our engine. It does provide some harmonic dampening, but that is mostly provided by the elastomer ring in the crank pulley itself, so you will be fine with the flywheel. Of course, it wont gain you any power, but it will accelerate faster, and it should be noticeably with a change like a flywheel. Just remember that it will shed rpm easier and you will end up with more engine braking effect (which is actually good if you track or autox it) since the engine now has less inertia at the crank to keep it moving. This increases the braking effect due to compression.
As for the exhaust, 3 inch is a total waste NA. But since we are talking boost it wont be bad, although it will probably be a bit overkill untill you start pushing more serious numbers.
When downshifting from high rpm, you most times will want to "heel-toe", or blip the throttle with one side of your foot while you brake with the other side. This allows you to downshift in the process and let out the clutch without creating a lot of stress and engine braking when you release the clutch. In a FWD this engine braking can be especially bad since you can induce throttle lift oversteer. A lighter flywheel means you can change rpm faster and get the engine spinning at the speed you want quicker.
You'll love the stage4 clutch! (well atleast I do...) and for the lightened flywheel, go easy on your 1st gear until your tires get traction and simply slam it after a second of wait, you should get an awesome 0-60 when done right.
Originally Posted by yamaha16bw
I have 3 inch cat back with Comp Stage 4 clutch with the Comp cast steel 9lb flywheel. I love all of it!
