6psi untuned...everyone read
Old Oct 26, 2009 | 04:28 PM
coryjames's Avatar
like i have been saying for years its not boost its temp baby all about temp say my 30r will flow very nice with some cold air where as a t3o4b will start to make tather hot air around 400hp my 30r will be right in the range where a turbo should be look at srt-4 stock turbo throwing out 20 pounds makes 300whp throw a 30r they are making the same power at 10-12 cooler denser air is all the rage you should know that lol
Old Oct 26, 2009 | 06:00 PM
ScionFred's Avatar
Sorry....CFM at a Given PSI on a Big turbo does not equal the same amount of CFM's at the same PSI on a small turbo. This is why you can not simply throw ANY turbo onto a stock ECU and think it will be alright as long as you stay at 6lbs of boost or less.
That's the point, the Air Temp will NOT be the same. Smaller turbos generate more heat for starters. And I've mentioned that it was more than just turbo size. People have added intercoolers (which obviously changes the piping), also some even put on injectors and think the Stock ECU can adjust for it. Adding an intercooler changes temps obviously as well.
Tire PSI has nothing to do with Turbo PSI...not a good comparison there. Again, you will not be pushing the same Temps.
I guess it's just the way I've seen it stated that I took issue with. Usually there is no mention of air temp, which is the only factor that can change the air volume at a given pressure. Honestly I didn't think there would be much air temp difference between say a T3-60 trim and a T04E 50 trim at 6psi. I assumed there wouldn't be a big temp difference until higher boost levels but I've been wrong before. Thanks for the info.
I suppose my unmanaged setup worked okay because it was a small trim T3/T04B with a small IC and only 6psi on stock exhaust. I never dynoed it but CXR did and only made 170whp (auto) at 5psi. I don't think the stock ECU is good for more than that and even then it's a potentially risky proposition.
Old Oct 26, 2009 | 10:33 PM
highvoltage1's Avatar
My comment was in regards to your unless its a 16g! I dont care what size turbo. Tunes save tC's! lol
Old Oct 26, 2009 | 10:38 PM
crush02342002's Avatar
good tunes save tc's
Old Oct 26, 2009 | 11:36 PM
thendawg's Avatar
I just pu -99 in all fuel cell - mines good to go 16.0 afr under boost is perfect right? Oh yeah and ignition map i didnt use that, thats only if you want less power i want MO POWAAAA
Old Oct 26, 2009 | 11:41 PM
coryjames's Avatar
i just went out for some retuning after i though i lost all my maps i am not not pulling timing till 11 psi hahahahahahah spools a little faster
eeeeeeeeeee afrs look good
12.2-11.8 all the way across
Old Oct 26, 2009 | 11:49 PM
advanced timing FTW!!!!!!!!!!!
Old Oct 26, 2009 | 11:52 PM
Even better^
Old Oct 26, 2009 | 11:56 PM
coryjames's Avatar
i want to run over 9000
Old Oct 27, 2009 | 01:27 AM
man i wanna so throw a pic up for that over 9000 comment but i cant threadjack.
evolving_machine
Oct 21, 2023 01:16 PM
GoodVibes
21
May 22, 2020 04:27 PM
yhwhdesign
Mar 7, 2015 02:01 AM
DougC
Feb 22, 2015 02:39 PM
stayintrucha
Scion tC 2G ICE & Interior
Dec 18, 2014 04:36 PM
