87 users SPEAK UP!
Originally Posted by forpinks
I had to go to my friend's house and checked the head for a broken valve and I thought my friend was joking when he told me that it is ported and has upgraded valves, springs and pistons, I checked and saw that the valves are actually painted black not bare aluminum and the head has slightly more area and is shiny, also the pistons look different from what I used to know since I was 17 when my friend and I opened up a 4A-FE (I don't know what I have, but they look like high comp forged pistons) This is probably the reason for the chug, my friend and I simply put in a bottle of NX octane booster and waited for 5 minutes till we started it, it chugged at first but after it warmed up, the weird sound was gone...
i am now dumber for having read this
man, you guys putting higher than 87 octane in an unmodded engine or no force induction are killing it. i mean, 87 is the best gasoline for the bang of the buck in economy fuel and mileage. anything higher, you're just making your car work harder to retard its timing and compression to make the 89 or 91+ stuff consumeable. it sure as won't get you more horsepower either because of this. so, you not only waste money but also gasoline, mileage, and horsepower while also doing more harm to the environment because using 89 or higher on an engine meant for 87 burns less thoroughly. i can say you buy the 91 octane with the detergent once in a while to clean the injectors but that's pretty much it.
and the thought of higher octane is giving the best for your car. it's not. its the other way around.
Actually no one really can say that 87 octane is better then 91 octane for our cars because really there are actually so many other factors. In actuality 91 should never run at a more "retarded" timing advance then 87 and in all actuality if it is a really hot day in theory you might even feel a power increase with 91. Also if the 91 you use happens to have a faster flame front you also might actually make more power. It’s all in the way the gasoline increases its octane. Most of the time there will be no difference but never will 91 perform any worse than 87.
Right now I use 91 because it is not that much more than 87 where I get gas. And also because I received $200 free gas with my car loan, so I am not really paying for it at this point.
I will go back to 87 when the cards run out. That is until the spring, then it will be 94 Octane from Sunoco.
gyrotech
Scion tC 2G Aero & Exterior
Oct 4, 2015 11:03 PM
Darrenohooligan
Sep 26, 2015 07:21 AM
umnitza
Jul 25, 2015 07:54 PM
