Advice please
The last time I ran my car my best pass was 13.7 @ 103 mph. most of the other passes were 14.0 - 14.2 @ 105. Now I plan to get the P-tuning turbo kit eventually. My question Is it really worth it to get it now. I am running on stock motor and I believe my times will not change that much. I don't want to spend 5k + on the kit exhaust and tuning to be .5 sec faster in the 1/4. Should I just build my motor and spray a larger shot?
as me n u both know there are times when u wanna let it rip but u realise your bottle is closed...and there are times where its empty, and the cost of filling it plus the cost of filling your gas... this is the reason i went back to boost instead of the 75 shot i had..
dont get me wrong i loved spray it was nice instant power but boost has the upper hand in availibility and long run cost
I haven't used nitrous since November. I only use it at the track because on street tires at the track I spin up to about 70 - 80 mph. If I get the P-tuning short block and Dezod PNP head and I get BC stage 3 cams what EMS should I go with and what would be a "safe" amount of nitrous to run?
i ran nitrous best time was a 13.9 with a 2.002 60ft this was a 60 shot, with the turbo best time so far is a 13.7 with a 2.595 60ft so the turbo is a lot more power, and its cheaper over all, plus you have power all the time Im happy I switched over
build and spray!!! turbos are played out.
besides, dont be so sure that getting a ptuning kit will automatically shave .5 sec off your time. i dont know of any ptuning customers running a 13.2 1/4 mile. come to think of it i dont know of any ptuning customers running at the track period...
You can run something like the APR unit.
http://www.dezod.com/pd_apr.cfm
That will allow for increased revs and retuning with the cams and N2O
mospeed tc went 13.9 at mir with ptunings kit....he had all season tires, a slipping clutch and was his 2nd time at the track with the manual trans, i believe he trapped at 105 or 109
jk not like i drive a 11 sec tc or anything..
I ran my 13.7 on street tires and that was my 1 st time running at the track.
I looked at the ADR unit and it says that it has no control over VVt-i. What units have control over VVT-i? If I am going to spray more I will need to retard cam timing or completely turn off VVT-i when I spray correct?
Also what compression ratio should I be looking at getting with the p-tuning block If I am going to be running all motor/ nitrous? I will be ordering a clutch soon and was wondering if I should get a stage 3 or 4. I already have a Fidanza 9.5lb flywheel just need a new friction plate.
I'm till trying to decide what I want to do. If I go all motor I would only expect 200 whp then I would want to spray a 200 shot.
I posted up a track meet March 7th @MIR, on Mid Atlantic section. 1st weekend track opens hopefully no snow.
Reason I switched was because it is not allowed in the racing I do.
