AEM F/IC not working
Old Dec 10, 2007 | 03:56 PM
tCarazy's Avatar
Default AEM F/IC not working
I installed a zpi stage 1 kit with the AEM F/IC as management over the weekend. Everything went smoothly, but my laptop could not detect the F/IC. I plugged the usb cable into the back of it and started up the AEM program, but it wouldn't load the maps I have and I couldn't connect to the controller. I have a plug and play harness from dezod if that makes a difference. Are there jumpers that need to be set for the tc like the e-manage blue controller has? Any help is appreciated.
Old Dec 10, 2007 | 04:41 PM
deathbyc4's Avatar
was the f/ic on when you tried to connect? i know it sounds like a dumb question but it's the simple things that cause the most headaches.
Old Dec 10, 2007 | 04:50 PM
paul_dezod's Avatar
Scionetics
KAD
Sounds like it may be a USB driver of sorts. They are ready to roll with no jumper or any changes that need to be made. Try un-installing and re-installing the USB drivers and try again.
Old Dec 10, 2007 | 05:10 PM
tCarazy's Avatar
The F/IC was plugged into the plug and play harness and the car was turned on, engine not running. I thought it might be a usb driver issue, but when I tried reinstalling the new drivers that AEM recommends it had no effect. Have you guys had success with the drivers they link to on their forum?
Old Dec 10, 2007 | 05:13 PM
paul_dezod's Avatar
Scionetics
KAD
I have had success with them. Even the ones straight off the install disc that comes with the FIC.
Old Dec 10, 2007 | 05:19 PM
tCarazy's Avatar
Ok that's what I figured. I'll probably just have my tuner take care of it. I was just making sure there wasn't anything I could really do in advance. Thanks guys.
Old Dec 10, 2007 | 05:25 PM
Mr_Meaty's Avatar
I did not have any issues with mine. In fact, I was able to connect to it with the unit sitting next to me on the couch, not even plugged into the car! It didnt' keep any of the maps I loaded that way, but it at least detected it.
Are you sure you are usign the right version of the software? Your unit probably has not been flashed yet, so you shoudl used the software on teh disc, not the 2.01 software on AEMs forums yet.
Old Dec 10, 2007 | 06:40 PM
tCarazy's Avatar
I did try and connect to it out of the car before I installed it, but I couldn't get it to pick it up. I'm going to try and reload the drivers directly from the cd one more time when I get home from work. One thing I noticed is that I can't even load a map (.mdb file) into the program. Are you supposed to be able to load a map without the F/IC plugged in?
Old Dec 10, 2007 | 06:54 PM
Mr_Meaty's Avatar
Yes. I had the software on my desktop just to see what it looked liek before I got my F/IC. I can run the software and then click "File/Open" and load an .mdb file.
What happens when you try to do that? And what OS are you running?
Old Dec 10, 2007 | 06:56 PM
tCarazy's Avatar
I'm running windows xp. When I try to load a .mdb file into the window, nothing happens. The file isn't even associated with the program. I have to choose to open it with the program. I've tried dragging and dropping files into the window, and still nothing happens. Any thoughts? That seems like it's definitely a problem...
Old Dec 10, 2007 | 07:08 PM
Mr_Meaty's Avatar
Well, I just go to file/open and click the file. Then the O, I, and all those icons become active. nothing changes till you click onthose icons.
Mr_Meaty's Avatar
Try downloading the software off their forums. Maybe your CD is bad?
Old Dec 10, 2007 | 07:11 PM
tCarazy's Avatar
Possibly. I'll have to try that when I get back. From what I remember, the only buttons that were active were the File/Open and About tab. Nothing became active when I tried to load the map. I know it's not the map because even the map that came with it doesn't load and isn't associated with the program.
Old Dec 10, 2007 | 07:12 PM
Mr_Meaty's Avatar
None of mine are associated with the program either. but the 0 map should at least load.
Old Dec 10, 2007 | 07:16 PM
tCarazy's Avatar
I'll try loading all the maps when I get back. I only tried loading the base map and the C map, so I'll give it a shot. I'm getting it tuned this week sometime, so my tuner will probably figure it out if I can't. Thanks for all your help! I'll let you know how it goes.
Old Jan 10, 2008 | 10:52 PM
Crippie's Avatar
1UP Crew
Any word on the issue?
Old Jan 10, 2008 | 11:47 PM
tCarazy's Avatar
I ended up running the car without management for a week without any issues. I took it into Church's dyno, and his laptop had no problem connecting with the FIC, so I'm assuming my software is bad. I still can't connect to the FIC from my laptop, but the car is running fine.
Old Jan 10, 2008 | 11:58 PM
Mr_Meaty's Avatar
So...you got a tune from church's?
Old Jan 12, 2008 | 04:11 PM
prpnum1's Avatar
Church's FTW! That's 2 FI/C done by Sean now.
Old Jan 12, 2008 | 04:32 PM
tCarazy's Avatar
Yeah, if anyone in socal is looking for a tuner, he's the guy to go to. I live an hour and a half away, but it was worth it.
