best sparkplugs
ok so i have the trd scer, along with full megan exhaust and a 9.5 boost pulley and nst lite crank pulley, and other small items, so i was told the plugs u get with the trd scer kit are crappy, so what plugs should i be running?
You will get the same results with either denso or NGK iridium. Both are stellar plugs. bkr7eix is fine although personally I would run an 8 heat range "bkr8eix" which is equal to the denso ik24 with your mods.
One thing I noticed on the tc under 10 psi, the car digs a wider gap. If you know how to gap iridium plugs "much different than a crap nickle tip" then set them to .040
1 step colder. I usually go around 1 step per 100hp gain which is a very "general" rule of thumb. Many other factors apply but the general rule works ok. You could go two and be fine. I am running 2 colder and it is perfect.
yeah but i am supercharged, thats y i started this post, and yes it is the colder plugs that do it, and apparently the plugs i got with the scer werent irridum, so it made the ik24s all the more better an upgrade
Yeah the sc comes with crap nickle tips. The iridium past a 7 heatrange usually come gapped at .032 unless it is an NGK and you order a wide gap, I changed mine to ,040 and it ran much better overall.
No they are set at .032 if you order denso's. You have to use a feeler gauge set and bend the arm, not touching the iridium tip to gap them. A slide gapper will damage iridium plugs.
