Best way to prime and break in turbo??
Old Oct 2, 2010 | 08:04 AM
05_ScionTC's Avatar
Default Best way to prime and break in turbo??
Well on Tuesday I will be putting my S1 kit on and what is the best way to prime it and to break it in?? Just getting insight from everyone whos dealt with it.
Old Oct 2, 2010 | 08:49 AM
Ace83's Avatar
Ronin Scion
i just started the car as normal, it will see get oil pressure at the moment you start cranking unless your oil feed line is very long
Old Oct 2, 2010 | 02:44 PM
gwopsta's Avatar
unplug ur fuel injectors, crank it a couple times to prime the turbo, plug em back up
badaboombadabing
Old Oct 2, 2010 | 03:54 PM
deathbyc4's Avatar
easiest way, unplug the ecu. crank it for a just a lil bit. then plug it back in.
Old Oct 2, 2010 | 04:47 PM
Murphys_Law's Avatar
will it even turn over with the ecu unplugged?
Old Oct 2, 2010 | 04:56 PM
deathbyc4's Avatar
same effect of unplugging the injectors and the safety of no fuel pump activation too. i unplug the ecu for a few things; ecu reset, compression tests, and priming the oil/collant system for the turbo since mine is water cooled but not as important as oil is.
Old Oct 4, 2010 | 03:35 AM
tcscion06's Avatar
remove the EFI relay and crank
evolving_machine
Oct 21, 2023 01:16 PM
my06tc
Jun 25, 2015 12:18 AM
LzeroKI
Scion tC 1G Aero & Exterior
Feb 5, 2015 06:09 PM
ScionLife Editor
Nov 25, 2014 03:00 PM
