Boost gauge help
So i'm doing my boost gauge and i cannot find a place to run the vacume line into the car. i searched and found nothing usefull. Can anyone help me out with. where to tap the line and where to tap for power for the LED's in the gauge? thanks!
ground out the negative (black wire) onto the body of the car somewhere
then for the positive (red wire) mine is tapped into a fuse that only gets power when the car is on (look for the one for accessories).
i would have done it off a switch source off your radio j and to get the boost line in wait till you have you vacuum block but go where the gas pedal wires go out or the clutch line some place like that i just drilled a new hole for all to go out
no.... there is a little cubby next to my cigarette lighter. in that cubby there is a light that only comes on when i switch my headlights on. i tapped into that.
SloTC1
Aug 16, 2018 02:45 PM
crimson_sinn
Sep 25, 2015 09:41 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
