Boost reading ?
Old Jul 10, 2012 | 03:46 PM
Jbarker1983's Avatar
Default Boost reading ?
I installed my boost gauge and when I start the car the needle stays on 20 and when I hit the gas raises up to 10 like the gauge has 0 -30 reading going up or going down I'll try to get a pic
Old Jul 10, 2012 | 05:08 PM
paul_dezod's Avatar
Scionetics
KAD
These readings all sound normal. The gauge reads from 30 inches of mercury to whatever amount of boost. Most gauges look like this:
So a reading of 20 inches of mercury at idle is perfectly normal.
Old Jul 10, 2012 | 05:09 PM
Yeh it looks like that it starts on 20 in the negative then when I get wot it hits 10 in the positive I have the s /c with 9.5 pulley so this sounds correct?
Old Jul 10, 2012 | 05:11 PM
BadDudeTC3's Avatar
Vac @ 20 is good at idle. Until you put some kind of load on the motor you won't go into boost if you're just reving it.
Old Jul 10, 2012 | 05:12 PM
paul_dezod's Avatar
Scionetics
KAD
With that pulley, sure does sound right.
Old Jul 10, 2012 | 05:53 PM
AnotherDude's Avatar
^^^ what they said.
I'm NA but my "Boost" gauge (Vacuum gauge) reads -20 at idle and goes up to 0 at WOT. 9.5lbs boost = 10 reading on your gauge is correct, it's supposed to show how much psi you're using in boost.
my06tc
Jun 25, 2015 12:18 AM
ILikeTurtles
Scion tC 2G Forced Induction
Mar 23, 2015 05:24 PM
sanders_scion
Mar 17, 2015 05:13 AM
sanders_scion
Jan 20, 2015 04:54 PM
spawnconnery
Dec 18, 2014 08:38 PM
