Need help ASAP!
Hello all,
I am trying to log the data given from my AEM Uego Wideband, but I'm uncertain of how. I also have a Greddy blue emanage and have seen people log their data through that software but I am not sure of what wire to connect to the Emanage. Any suggestion or guide to the right link would be extremely appreciated. Thank in advance!
And also, do you guys normally see the "check engine light on" after the turbo installation? It wasn't on at first, I took it out for a test drive, "did not drive it hard at all" and I noticed the check engine light on after I restart the car! What are some potential problems I might have?
Thanks again for your help!
Not sure the exact specs of the AEM UEGO Wideband, but usually for datalogging capable devices, you have to get either a Usb cable to hook it up to the laptop, or a Serial to USB cable to hook it up. Then you install their propriety software, in your case an AEM software. Thats pretty much the gist of it.
Oh if you do required a Serial to USB cable, you have to install the drivers for that as well, it usually included on a cd, or you can get it off the manufacturers website.
As far as the Turbo installation, I didn't have a check engine light when I originally installed mine. Did you change the location of your secondary O2 sensor? Are all the sensors properly hooked up? Check for any air leaks?
