can i connect boost gauge to compressor?
i dont know but idealy you want to tap into the line that comes off the throttle body.
unless you have a vac block then you just plug it into the block and tap the block to the brake booster line.
i have very accurate readings and almost all vac blocks on the tc i have seen are taped into the booster line. i have my wastegateline, blackbox/pressure sensor line, boost gauge and BOV line all going to my vac block that taps into the booster line. accurate readings. zero issues.
haha ok and i had the tb hose taped before for my gauge and it would just fluctuate so much at idle and around like 8 vac....
would brake boost be more stedy or does that get effected by evap also
ok so i taped the brake boost for my boost gauge...not with a vacuum block i just used reducers and taped direct and its on the dot no fluctuation of the needle java probs again thanks
you might still see fluctuations at times, depends on your gauge.. vacuum pressure is sensitive and easily changes to throttle position, load, rpms, ac on/off, fans on off and such.. if you have a digital boost gauge you will see constantly changing numbers
you dont have to get digital though, i cant speak much about sun pro hopefully they are accurate enough.. but yeah i never had problems with the brake booster as vac source so you're good with that
my06tc
Jun 25, 2015 12:18 AM
mattjk
121
Dec 22, 2004 10:49 AM
