Car wont start after installing turbo
Ok so today i installed my turbo kit i made. Everything like lines, and all components are hooked up and bolted down. what it does is it starts up and eventually stalls and dies. But if i disconnect the maf it runs fine. but with it on it dies. I have the intake maf running of the turbo intake. Any one have any suggestions for me? Need help asap.
so to speak it will...sounds like a leak somplace near the maf. make sure it is seated properly, facing the correct direction, and couplings are tight.
any codes? if so what are they
Ok i am working on it today after work. So what i got is the ecu will calibrate to the 440cc injectors correct? And i know not to go into booost until tune. I made sure the maf is facing the correct way also. I have it running off the cold side of the turbo now. SHould i put it in before the tb and before blow valve. So it would be like this... Tb, maf sensor, then bov?
Throttle Body,MAF, BOV is correct when running blow-tru. Running blo-tru is better than draw-thru but that is your decision. The ECU will never recalibrate for larger injectors. The fuel maps have to be adjusted and along with the Air and Timing. Also suggest posting pics so we can help you better.
Also,what specifically are you getting the E-Blue or E-Ultimate??
drivable maybe but i know for a fact that my car still turned on and had a normal idle without my fic when the 550cc injectors where in.
will the stock ecu still let the car idle if he does try and set it up for blow thru? i thought u had to tune it for that since the maf is so far from the intake the car wouldnt start up right away.
