CarbonXe is boosted. 287.2/272
Actually, you were right. This morning I just discovered the Gauges feature in FIC, which shows boost/vac as load. It also highlights on the fuel map EXACTLY what the car is running at. I found that out this morning after I got to work, after I made a bunch of adjustments to cruising. Right now..
Cruising - 14.5-15
Uphill cruising - 14.5-15 (gonna give it 1% more fuel)
Downhill cruising(using cruise control, not OT) - 12.5-13 (couldn't find it on the map lolz)
Also reaching the 10 gallon used mark. First tank I got 168 miles on 10 gallons, this tank, with basically only idle adjusted and same driving habits (lots o boost) I'm up to 200 miles and I've still got 1 gallon togo. So my gas mileage is slightly improving, hopefully now that I'm not cruising at 12.3 constantly, I'll be able to hit mid 20s.
Cruising - 14.5-15
Sort of, lol. I had no clue about the gauge function, and when I opened it, the boost/vacuum gauge was titled as LOAD.
I still think my O2 map is way off. I'm getting a system too lean everytime I start the car. P0171, looked it up and said common causes are dirty O2 or vacuum leak. The O2 isn't dirty and I hold a steady 24hgIN at idle..
So, should my O2 map be 0-1v or 1-5v? I have different tunes and the O2 maps vary... I don't want to switch it out to test it unless I'm certain about it, mainly because I'm so close to finishing my fuel map.
Alright, the majority of the tunes I have pretty much have 1.7v for boost, 2.1-2.6 for just entering boost and 3.2 for vacuum, so I'm going to attempt to make a new fuel map for this new O2 map. I still have my old tune, which I know the car runs fine on.
That's what I've been doing, but since I have to make such a major change to the O2 map, I don't know where to start with the fuel map. I might just say F it and keep running the map I was running.
I have about 10 tunes, 2 of them are utter garbage, 1 of them runs perfectly (my personal one), and I don't remember what the other ones were set to for injectors.
Yeah, it fired up and ran slightly rich all around when I put in my own tune. Everything else...it runs like ___
I'm just going to stick with my current tune.
Chris, once you get tuned, send me yours, I want to compare. Also, I sent you an updated version of my tune.
