CarbonXe is boosted. 287.2/272
Old Nov 26, 2008 | 03:52 PM
  #1481
java09's Avatar
after i install mt kit this friday ill be getting the qtp 3'' cut out welded in and if they have time get it re tuned with my emanage... then wait to either go with FIC or hydra when i build the motor..
what kind of numbers you think ill see at 9-10 psi with my twin scroll set up?
old set up:
El mani, t3/to4e, 9.4 psi, 2.5 dp, 2.5 s pipe, 2.5 spipe back exhaust
new set up:
EL twin scroll mani, GT3071R, 3 dp, 3 s pipe, 3 qtp electronic cut out
how much you think ill make at the same psi?
hopefully more.. if its less ill be ____ed! ahahah
Old Nov 26, 2008 | 03:56 PM
  #1482
paul_dezod's Avatar
Scionetics
KAD
old set up:
new set up:
Depends on tuning. The open dp will allow for about 1-2 PSI of boost and the 3" will allow breathing as well. So, in all you may end up picking up 2-3 PSI more of boost on the car.
Old Nov 26, 2008 | 04:00 PM
  #1483
CarbonXe's Avatar
No comments on the numbers paul? I've got a few parts from you in there .
Old Nov 26, 2008 | 04:03 PM
  #1484
java09's Avatar
old set up:
new set up:
so you mean ill pick up 2-3 psi safely of power..
what i mean is i dont want to exceed 10psi.. till my motor build.. my tuner does a good job
old set up 310whp 272wtq.. any idea of the power i may see? thanks paul!
  #1485
paul_dezod's Avatar
Scionetics
KAD
Oh. I thought I did comment on this thread already..........Anyway, I saw the curves. Looking good for sure. Quite a bit of boost to make that power overall IMO, but the power curves are nice.
Old Nov 26, 2008 | 04:04 PM
  #1486
paul_dezod's Avatar
Scionetics
KAD
old set up:
new set up:
Safely, doubtful unless the car is tuned so rich that it can afford to have some fuel taken out. A definite retune will be needed.
Old Nov 26, 2008 | 04:06 PM
  #1487
java09's Avatar
^^that much is true! different everything! but i mean after the re tune!
Old Nov 26, 2008 | 04:08 PM
  #1488
CarbonXe's Avatar
With a new tune, I'll be making the same power and more torque on 10PSI. It was running insanely rich at lower RPMs so the torque couldn't build up, which directly affects power. I'll have new numbers this spring when/if PTuning tunes it.
Do you guys tune F/IC's? If PTuning won't tune the F/IC, you're my only other option. Aside from the obvious, ditch the F/IC and get the E-Manage.
Old Nov 26, 2008 | 04:09 PM
  #1489
paul_dezod's Avatar
Scionetics
KAD
Depends on the tune overall. Assuming a similar AFR tune and just the new exhaust and turbo manifold combo.............Maybe an extra 10whp and a few lbs of TQ gain. I would not expect rocket type numbers.....
Old Nov 26, 2008 | 04:11 PM
  #1490
CarbonXe's Avatar
Ya know what's funny, someone on the NJTuners boards pointed this out...
My HP and TQ cross at 5252 RPM .
Old Nov 26, 2008 | 04:13 PM
  #1491
paul_dezod's Avatar
Scionetics
KAD
Funiest thing is he does not know the calculation for HP then.
Old Nov 26, 2008 | 04:14 PM
  #1492
java09's Avatar
sweet! thats all i was hoping for.. once the motor build comes then i want rocket numbers..
imma rocketman.. im not the man they think i am back home.. Ohhh No No NO... IMMA ROCKETMAN!
Old Nov 26, 2008 | 04:57 PM
  #1493
Ace83's Avatar
Ronin Scion
Im thinking that your afrs might run leaner with the 3" and qtp at same boost level, there will be more air flow while the fuel pulse width stays the same
Old Nov 26, 2008 | 05:00 PM
  #1494
paul_dezod's Avatar
Scionetics
KAD
Suddenly Rocket Queen by GNR comes to mind.
Old Nov 26, 2008 | 05:03 PM
  #1495
java09's Avatar
hahaha.. when i re tune im shooting for the same afrs.. from 11.5-12.3 WOT..
im hardly ever in boost so even a little leaner in my eyes is no big deal..
Old Nov 26, 2008 | 05:05 PM
  #1496
java09's Avatar
Old Nov 26, 2008 | 05:11 PM
  #1497
paul_dezod's Avatar
Scionetics
KAD
Huh..........Never heard November Rain 2 or Rocket Queen 2.....
Old Nov 26, 2008 | 05:40 PM
  #1498
java09's Avatar
idk.. haha my dad will 100% know! biggest GNR fan of all time!
Old Nov 26, 2008 | 05:47 PM
  #1499
paul_dezod's Avatar
Scionetics
KAD
Yeah? I am a decent GNR fan. I grew up listening to it amongst many other groups. Appetite for Destruction = Best GNR album EVER
Old Nov 26, 2008 | 05:49 PM
  #1500
java09's Avatar
imagine the most filipino looking guy ROCKING OUT! hahaha i saw pics of him in high school with his VW bug racing click and its so funny!!!!!!!!!!!!!!! hahahahhaa
