CEL on my S/C'd TC
Old Dec 20, 2005 | 02:54 PM
SuperWTC's Avatar
Originally Posted by dachmo
Originally Posted by SuperWTC
Originally Posted by Munch
The O2 on the s-pipe is alot cheaper than the other one. Who installed your charger?
I installed it myself. Im 100% sure everything i did is correct. There was no detail left out nor a shortcut i took. Could it be fuel?
Did you do the SC reflash after you installed it?
Yes i did. The CEL came on again. I was driving under noraml conditions too. IDK must be broke! lol
Old Dec 22, 2005 | 05:42 PM
WeDriveScions's Avatar
Did you get this checked out? What was the problem?
Old Dec 22, 2005 | 09:31 PM
trdsparks's Avatar
Just take it to the dealer. The car is still under warranty.
Old Dec 23, 2005 | 03:43 PM
SuperWTC's Avatar
Even though i installed the unit myself?
Old Dec 23, 2005 | 04:12 PM
trdsparks's Avatar
Well unless you damaged the A/F ratio sensor (don't know how you could have) or installed something wrong you full warranty is still intact. The only thing that isn't covered under the "Factory Warranty" is the S/C. It's covered by the TRD warranty parts only warranty if it was installed properly.
Old Dec 23, 2005 | 05:39 PM
tikbhoy's Avatar
you said you never touched either afr and o2 sensor but it never hurts to check it against a ohmmeter.
on the service manual it shows how much resistance on each connector. make sure battery is disconnected.
Old Dec 24, 2005 | 05:42 AM
SuperWTC's Avatar
Awesome.. ill look into and let you guys know what i find out...
Old Dec 25, 2005 | 03:54 PM
zoltiz's Avatar
N.G.S.O.
My SC'd Matrix threw a CEL regarding "low catalyst efficiency". The cat was burned out because I put an intake on the TRD SC, and that caused the a/f to lean out and exhaust to get hot enough to ruin the cat.
Cats don't burn out for no reason - if you get it "fixed" under warranty - you'll end up with the same CEL in 3 weeks, unless they find the reason why your cat burned out.
Old Dec 25, 2005 | 10:35 PM
tikbhoy's Avatar
i have megan combo and im using antifoulers from kragen, its been 90+ miles and no CEL
good luck and see if your AFR sensor is good. i got mine for 170+tax.
ColonelSanders85
Dec 9, 2020 09:44 AM
Greg S
Jul 21, 2016 07:28 PM
MeDizzy
Oct 8, 2015 03:31 PM
Kanchi
Jun 29, 2015 02:42 AM
rshissler
Mar 24, 2015 10:46 PM
