Cracked energy poly mounts, now what?
Old Apr 23, 2010 | 01:40 PM
gompka's Avatar
Default Cracked energy poly mounts, now what?
Has anyone else managed to crack their energy poly engine mount inserts? My rear one has a big crack in it, it goes vertically straight down the middle from the metal bushing. Any other options available or should i just replace with another energy insert?
Old Apr 23, 2010 | 02:11 PM
crush02342002's Avatar
is it a surface crack or does it go all the way through?
Old Apr 23, 2010 | 02:31 PM
ElevationTC's Avatar
Id say its probably fine. But id need to see pics!
Also whats the update with ur motor?
Old Apr 23, 2010 | 03:09 PM
gompka's Avatar
Looks like the crack might be all the way through, but i'll have to pull out the mount and take a closer look.
The motor looks fine, still need to take the oil pump apart and take a look, but seems like it was a valve problem. Bearings are perfect, no play, waiting on stainless valves from dezod at the moment.
Old Apr 23, 2010 | 03:17 PM
rangerryda's Avatar
As long as the two pieces aren't coming out, they're pretty much doing the same thing as one solid piece.
Old Apr 23, 2010 | 03:38 PM
gompka's Avatar
yea the bushing is in there tight and it doesn't look like its going anywhere, guess i'll just leave it in there for now.
Old Apr 23, 2010 | 04:51 PM
on a couple of cars iv seen those mounts have a crack that looked bad but as soon as you get that bastard off and take a closer look its just a surface crack.
Old Apr 23, 2010 | 05:39 PM
Wounder if it was a sticking valve guide..
Old Apr 23, 2010 | 06:09 PM
trd07tc's Avatar
what do u do when other things break? replace it
Old Apr 23, 2010 | 06:30 PM
gingles's Avatar
Old Apr 23, 2010 | 07:34 PM
torqueTc's Avatar
x3. I agree. Replace it, send it back to the company so they can look at the problem and possibly make an improvement to the broken part so it may not happen again. If you sweep problems under the run, no one will ever know how to fix it.
Old Apr 23, 2010 | 09:36 PM
paul_dezod's Avatar
Scionetics
KAD
Your REV valves left the other day from them Dave.
Old Apr 24, 2010 | 02:25 AM
Prophecy2k4's Avatar
That's pretty impressive, what kind of a setup are you running to have managed to crack it?
Old Apr 24, 2010 | 05:47 PM
gompka's Avatar
well i'm not sure when/why it cracked, could have been when i dropped in the motor.
SoCal_CJ
Jan 27, 2023 05:42 PM
SoCal_CJ
Scion tC 1G ICE & Interior
Dec 31, 2016 05:13 PM
DJrepresent
Aug 12, 2015 06:37 PM
Subaru86
Jul 31, 2015 04:33 AM
HATEnFATE
Regional - Plains
Jul 29, 2015 05:53 PM
