custom turbo-kit: MO-CO style
Old Feb 11, 2009 | 07:57 PM
  #41
chicotunner07's Avatar
^you're a risky fellow! lol
good luck!
Old Feb 11, 2009 | 08:14 PM
  #42
youngflyer's Avatar
^ same thing as a zpi stage 0 kit untuned. as long as hes running low boost (sub 6 psi) his afr's should still stay within decent limits. Im guessing over time he will add on to this kit and make it a monster but for now, it will do the job! when its finished, i cant wait to see it in action....martin, you did fix the mani right?
Old Feb 11, 2009 | 08:19 PM
  #43
mospeedtc's Avatar
BOOM.... that is all LOL
everyones wishing you luck martin.keep your fingers crossed
Old Feb 11, 2009 | 09:37 PM
  #44
Ace83's Avatar
Ronin Scion
I still say its risky even on low boost, if he doesnt have a boost gauge or afr gauge to keep it in check. He has no management and stock ecu is not designed to give rich afrs below 12:1:1.. i remembered a stock tc at WOT only having low 14 to high 13s afr, that what our ecu is tuned for..
Old Feb 11, 2009 | 09:56 PM
  #45
youngflyer's Avatar
he has a boost gauge, just not an afr...well he has an afr but he has to pull it out of his dsm i guess
Old Feb 11, 2009 | 10:44 PM
  #46
unxpectederror's Avatar
Originally Posted by draxcaliber
3 psi? please, hand held battery powered fans blow harder then that! LMAO
i bet that even at 3psi he would see just as much bower as the 7psi of the s/c kit
Old Feb 11, 2009 | 11:24 PM
  #47
chintastictc's Avatar
lmfao hahahaha ur probly the most creative cheap person i know!!!!!!! lmfao...good luck
Old Feb 12, 2009 | 01:15 AM
  #48
cburglb34's Avatar
yea i mean i ranit like this before and yea i have a boost gauge...not a wideband my dsm has a narrow band..FAIL
Old Feb 12, 2009 | 01:56 AM
  #49
youngflyer's Avatar
oh im still trying to figure out the difference between wideband and narrow band
Old Feb 12, 2009 | 01:58 AM
  #50
Old Feb 12, 2009 | 01:59 AM
  #51
cburglb34's Avatar
narrow band doesnt do much just tell you if ur lean, rich or stioch.....wideband tells u exact numbers ...like my narrow band could say im lean...but idk how lean....unless i get a wideband..
Old Feb 12, 2009 | 02:00 AM
  #52
MrBurrito's Avatar
on goes around fat people and the other on skinny people lol
Old Feb 12, 2009 | 02:03 AM
  #53
youngflyer's Avatar
damn i guess i need a wideband lol, no i did some searching on google and found some good explanations
Old Feb 12, 2009 | 02:06 AM
  #54
cburglb34's Avatar
yea wideband is a must when tunning...if ur tuner doesnt have one or u dont....RUN and NEVER come back...... but yea ran a narrow on the dsm cuz i had it tuned a lil rich so i used a narrow band just to know im still rich and if it happens to say lean...im ____ed
Old Feb 12, 2009 | 04:40 AM
  #55
thendawg's Avatar
Man id really suggest doing a meth setup on it - i ran 5 psi untuned for about a week when it was 80-90 degrees here and on 91 octane id get a ping in higher gears so i ended up not driving it in boost - after the first week i added meth, my fic, and 440cc injectors, even befor ei started my street tune i ran it with just the meth engaging at 3 psi (controlled by my fic) and it ran MUCH smoother, a tad richer, and much safer - no knock counts on the ecu, no misfires, and no ping. Id highly recommend it if youre not tuning it right away as a little bit of safety - however im in no way saying it could replace a tune
Old Feb 12, 2009 | 05:12 AM
  #56
youngflyer's Avatar
yea wideband is a must when tunning...if ur tuner doesnt have one or u dont....RUN and NEVER come back...... but yea ran a narrow on the dsm cuz i had it tuned a lil rich so i used a narrow band just to know im still rich and if it happens to say lean...im flipped
it was a joke lol
Old Feb 12, 2009 | 11:50 AM
  #57
cburglb34's Avatar
why not just a fmic why meth also
Old Feb 12, 2009 | 07:56 PM
  #58
enjoithis's Avatar
FMIC > Meth
but, FMIC is not as effective when its 90 degrees out on a hot summer day! If your tune was done at 50 deg, when it gets hot out you will not run as smooth... Meth is a nice way to fix that problem.
Old Feb 12, 2009 | 08:02 PM
  #59
cburglb34's Avatar
ok so kit is for sale-750 SHIPPED
Old Feb 12, 2009 | 08:07 PM
  #60
enjoithis's Avatar
why you selling now?
btw wrong secion for selling
