dezod black box wiring?
Old Dec 26, 2006 | 02:32 AM
mike6789k's Avatar
Originally Posted by deathbyc4
ok, so i got a black box. Now, from what im reading I can set all fields to 10 and not affect the afr to the ecu. so, once I get it on, i an drive it to the dyno with it hooked up. First problem solved. my main question is, how will i know what to put for a value under 10 to richen it and at what rpm range? And what does the vacuum on this unit do for me if I have to type all this in? I know it sounds kinda noobish, but its good info to know for those looking to buy this.
well, i can tell you that the vacuum will tell the unit when you are in boost (regardless of throttle posistion)
as far as the adjusting the values that are set to 10 originally... well, thats the part im scared will be too hard for us to figure out!!!
dezod, can you just give us a diy on how you pre-programmed the boxes? since you had no idea what car the box was going on, there had to be some step-by-step process to program the boxes... can you release this?
Old Dec 26, 2006 | 03:25 AM
Joe_Dezod's Avatar
Even in vacuum, the turbo can still be spooled, and pushing more CFM than stock. You can adjust this to add a little bit of fuel for lowering EGTs. You can adjust your idle as you wish, but 14.7 afr is perfect. There is no DIY on how we pre-programmed the boxes. When purchasing the unit, it comes with very detailed instructions, one being the one posted above. For those that opted to tune themselves, they'd be tuning themselves. I'm not trying to come off harsh Mike. We added the $30 charge for those wanting to pay us for the added convenience. If you want to tune it yourself, you can. As with anyone else. I can tell you that you should never need to type in a value lower than 8. Hopefully that helps you. Anything between those values goes from about 9.5-14.7(at the 10 setting).
Old Dec 26, 2006 | 04:32 AM
mike6789k's Avatar
how come you stopped offering the pre tune? can we still pay a little more so you guys tune it for us?
Old Dec 26, 2006 | 01:14 PM
deathbyc4's Avatar
i can work with 8-10. Decimal math, here i come!
Old Dec 30, 2006 | 06:35 PM
soros151's Avatar
watching, also can I tap my E-manage Ultimate P&P Hanress instead of the OEM harness?
Old Dec 31, 2006 | 12:40 AM
Schuller's Avatar
Yes, that is exactly what I did.
Old Dec 31, 2006 | 12:43 AM
soros151's Avatar
Niceee
Old Jan 21, 2007 | 02:42 AM
pollup's Avatar
watching about the pretune
Old Jan 21, 2007 | 04:51 AM
deathbyc4's Avatar
I still would like someone to download the pre tune map and perhaps release it inconspicuously on the internet......
Old Jan 21, 2007 | 11:49 PM
malloynx's Avatar
did bob bailey have anything to do with the design of this box. just wondering.
Old Jan 22, 2007 | 12:52 AM
deathbyc4's Avatar
I'd shoot some money towards the first person to PM me with the pre-tuned map.
Old Jan 22, 2007 | 01:22 AM
mike6789k's Avatar
guys, i dont think its that simple... if it was that simle to just take a map and put it on your unit, dezod would still offer the service to pre tune...
the process of putting in a tune is very cumbersome and this is why dezod doesnt want to pretune anymore....
Old Jan 22, 2007 | 01:29 AM
zer0's Avatar
An owner of a Black Box already can either rip the tune off and put it to a file, or take a screen shot of the tune so they can plug in the #'s themselves... It would be awesome if Dezod would do that.
Old Jan 22, 2007 | 01:36 AM
mike6789k's Avatar
im sure dezod would have no problem doing so if that was the case... after all, dont they want more people to buy their box?
Old Jan 22, 2007 | 01:38 AM
zer0's Avatar
exactly, im almost ready to make the purchase.
Old Jan 22, 2007 | 01:52 AM
deathbyc4's Avatar
Ok, It's so simple to get the map off the box. connect with serial cable, select the appropriate com port, connect, then read ecu settings. It saves it to a .MDB file ( which most would think would be a microsoft database file but this one is formatted differently). Then you can pass it like an MP3 on version 1 Napster (yes the free Napster). Just involves getting a laptop and a serial cable and internet.
Old Jan 22, 2007 | 02:04 AM
mike6789k's Avatar
ok so it's not a big deal... someone do it already
Old Jan 22, 2007 | 02:25 AM
pollup's Avatar
i believe the pretune is still offered. been talking with dezod about getting one of these for my low end rpm afr spike issue.
Old Jan 22, 2007 | 03:26 AM
krdshrk's Avatar
Dezod said that it was such a pain to pretune it that they would not offer the pretuned option anymore after the initial run.
Old Jan 22, 2007 | 03:30 AM
deathbyc4's Avatar
I've spoke with them about it, but it's not hard to send an e-mail with the file. They don't even offer to sell the file. I would even pay for it since I got the box after the GB, just to cut down on the tuning time on the dyno. So if someone will upload the file, money will come your way.
