Dezod mani problems w/ custom 3" exhaust/downpipe??
Sooooo, i'm having a custom 3" downpipe and exhaust made. I just purchased a v-band 5 bolt flange. I've been reading about a few people and their problems with dezod turbo mani's cracking, and a few instnaces with custom 3" exhausts. I think one of them was SoFlo but i'm not sure... So my question is should i do a full v-band all the way back? (my understanding is that v-bands provide for some flexability)
Or should I use the spring bolts that come with the stock exhaust and use them on the end of the downpipe along with the v-band fitting at the beginning of the downpipe.
Also, i'm looking for something as quiet as possible, any suggestions on resonators/mufflers?? i was thinking about the 33" resonator from magnaflow.
p.s. the downpipe will have a 3" cat in it too....
well, i'd like to attempt to pass emissions here in IL and after reading thats probably the easiest way. Also, it'll quite down the exhaust a lil. Plus its an added bonus that I'm being a lil more "green" LOL. As far as the flex pipe, where should it go?
^ yep.
I ran my dezod kit with an aftermarket exhaust with the spring bolts, and then when I made my custom 3" I just put a flex pipe in, and there are not any signs of cracking whatsoever when i changed my kit out. And honestly, I only run a muffler with my full 3 inch exhaust. It's not really that loud. The EL manifold makes it quieter than when i had the dezod kit, but if your woried bout noise, It's not that bad.
Turbo Toyotas EL mani. As much as Todd is hated, the manifold isnt too bad. I kind of wish I just made my own though. Its the only thing that isnt custom on my kit, and I probably could have made things fit better with my own mani. Me FTL
You don't need a cat to pass emmisions all you need is an anti-fouler, if your don't have a check-engine you will pass. They don't do a tailpipe test for obdII cars.
^^ but i've read other posts that show that the anti fouler trick is hit or miss. I also kinda feel that having a cat in the downpipe is gonne be hit or miss as well though.... LOL i have no factual basis for that feeling, but i just feel that way.
Well the anit-fouler is $5 to try, so it couldn't hurt. And if that works then your problem is solved.
As everyone has stated. You can run whatever type of flanges you would like so long as there is a way for the exhaust to flex. If you eliminate flex all the stress is applied to the manifold and that will make any manifold crack. So put a flex in the exhaust and if you are making a new downpipe fab a bracket to bolt it to the block so it doesn't move and the exhaust can flex separately.
SloTC1
Aug 16, 2018 02:45 PM
umnitza
Sep 1, 2015 08:06 PM
umnitza
Jul 25, 2015 07:54 PM
