dezod turbo kit issues
Old May 29, 2014 | 12:06 PM
bllackoutx90's Avatar
Default dezod turbo kit issues
ok everyone. having some slight issues with my maf sensor. so after my install which i believe i installed correctly lol on startup it turned right over. 2 problems.. one CEL which reads maf circuit low input fault. 2 im running stupid rich on fuel. so i was told it could be the maf sensor that is making it run rich but not sure how to fix that. i called ptuning because im taking it there to get proffesionally tuned tomorow and told them and they said they recommend replacing the maf before i bring it in and if it still reads the same problem it most likely can be fixed within the tune. well i replaced the maf and... same problem. still taking it in tomorow but i want to be certain that something isnt messed up. so if anyone else had run into this sort of problem your suggestions would be great. thank you
Old May 30, 2014 | 01:06 AM
That_Kid_Ju's Avatar
If you unplug the maf sensor without disconnecting the battery, that code will come up. Happens to me everytime I clean the maf. Clear the code, let the car re-learn idle, and if possible, drive it around (out of boost of course) until the obd port is in the "ready" state. If there's a problem with the maf, it'll pop up once again in that time frame. Most likely will pop up when you turn the car off, then start again if there is a problem.
Old Jun 6, 2014 | 04:41 PM
paul_dezod's Avatar
Scionetics
KAD
I'd hardly say it's a kit problem. The sensor is indepedant from the kit. And Julian has you on the right track.
helloninja
Mar 19, 2018 04:50 AM
Brammi
Nov 13, 2016 03:46 AM
my06tc
Jun 25, 2015 12:18 AM
darkshadowofxdeath
Feb 11, 2015 05:38 PM
greytc
Jan 12, 2015 09:49 PM
