Different wg spring or boost controller
Ok I want to run more boost in my car but I got a 6psi spring now, would i be safe if i just get a different spring to run higher boost or i need to get a boost controller? I am wanting to run like 10-12 psi
boost controller. i got one used for 50 dollars. a new spring is 30, so for 20 more dollars you can get a boost controller and change it to whatever PSI you want! and it's easier becaue you don't have to take apart your wastegate.
Sent from my iPhone using Tapatalk
I usually just change the spring - You can get one for $20-$35 usually. I think getting a spring is much better and more reliable than the MBC, just one less thing to fail. Unless you are running a tune that utilizes more than one boost setting - Ex. 8psi daily and 12psi track then I would get the MBC. Good luck
i know at high boost you can even use a small spring for it too. you have to do a "push pull" i think is what it's called set up with the wastegate though. where you use the top port of the waste gate as well
evolving_machine
Oct 21, 2023 01:16 PM
my06tc
Jun 25, 2015 12:18 AM
carid
Feb 12, 2015 11:54 AM
Beesh
Jan 9, 2015 06:30 PM
spawnconnery
Dec 18, 2014 08:38 PM
