DIY-AEM F/IC-now with 2-Step launch control
56 Attachment(s)
Here is a Vid to prove it...this is just a test to check it out and I need to do a bit more before i post a DIY on it. parts are cheap for it and doesnt require much to do really.
Also in the Vid iv got the bottom part of the stock air box off so it sounds a little beefier if anyone was wondering. http://i264.photobucket.com/albums/i...h_MVI_1692.jpg again this is just a test so far. _____________________________________________________________________ AEM F/IC 2-Step DIY This is for off-road use only and is done at your own risk!!! Supplies AEM Fic Attachment 97201 Fic Harness Attachment 97202 Shrink tube Attachment 97203 Crimp Connectors Attachment 97204 14 Gauge Wire and 24 Gauge Wire Attachment 97205 Attachment 97206 Molex Micro-Fit 3.0 Socket Crimp Terminal (This is if you dont have a spare universal harness to pull pins from and using the boomslang pnp harness. If your hardwired using the universal harness your one lucky guy cause youll save yourself some time) Attachment 97207 Attachment 97208 12 Volt 30 Amp Relay (Five pin relay with one "normally closed" contact) Attachment 97209 Small Limit Switch (aka Mini snap action switch) Attachment 97210 Attachment 97211 Zip Ties 12 Volt 15 Amp Toggle Switch Velcro Tape or Double Sided Tape (optional) Self Taping Sheet Metal Screw (optional) Red Bull (almost manditory..lol) Attachment 97212 Most of this stuff can be found at Fry's electronics except for fic, pnp harness, molex pins. Fic and harness can be found at www.dezod.com and molex pins can be found at www.alliedelec.com . --------------------------------------------------------------------------- Tools Crimpers Stripers Multi-meter (for checking connections and trouble shooting) Attachment 97213 Flat head screw driver Tiny drill (skill xo, ryobi 4volt driver, etc) (optional) Philips head screw driver (optional) Solder Soldering Iron Knife Lighter or heat gun ---------------------------------------------------------------- Pre-wiring We will start with the relay, take note of the wiring diagram thats on it. Almost all relays have a wiring diagram that will tell you what pins do what. Break out the relay and find the two pins for the coil. You will need to either pull out a pin from the Fic universal harness or you'll need to grab the 24 gauge wire. Take one end of that wire and crimp on a female spade connector. Heat shrink the wire and connector so nothing can make contact with it from the sides. Plug this wire into one of the pins for the coil on the relay. On my relay this pin is labeled 85. Attachment 97214 Take the other end of that wire and crimp on a molex micro-fit 3.0 terminal. If using a wire and terminal pulled from the fic universal harness then no need for crimping a molex terminal on. Now we need to find pin 16 on the 24 pin connector, on my harness pin 16 is on the top row right next to the green wire. Attachment 97215 If still unsure of which pin look through your fic wiring instructions thats on your install CD, it will have a complete pin-out for both connectors that plug into the fic. Now take that wire we were just dealing with and push it into pin 16 of the 24 pin connector. It should look like this Attachment 97216 Make sure you have pushed it in as far as the others, if it doesnt stay firm in the connector or isnt pushed in far enough you will not have proper contact. Now move to the one pin for the coil of the relay thats left. Its labeled 86 on my relay. This is were we are going to bring a ground to that will come from the limit switch that will be mounted under the clutch pedal so make sure you cut yourself enough wire to do so. It will roughly take about 10ft of wire to be on the safe side. Unroll some 14 gauge wire for this and crimp on a female spade connector. Heat shrink it to be safe after its been crimped, plug it into the relay. Next we will need two long runs of wire roughly 15ft long each. Thes will go from relay to engine bay. Crimp on one female connector per wire and heat shrink them. One will be pluged into the common terminal of the relay, on my relay its labeled 30. The other wire needs to be pluged into the relay pin thats a "normally closed" contact. This pin is labeled 87a on my relay. So far everything should start looking like this Attachment 97217 We are almost done with the relay, just need to tape it up to the Fic pnp harness (or mount it someplace in the glove box later) Attachment 97218 Attachment 97219 Attachment 97220 Now we need to splice into the wire thats connected to pin 30 on my relay with another 14 gauge wire thats roughly 5ft long depending on where you tap into. this is one is for the bypass switch (12 volt toggle switch) so you can activate or deactivate the 2 step. Then you will need to take another 5ft long piece of wire and tap into the wire coming from pin 87a on my relay. This too is for the bypass switch. I suggest to make your connections by peeling back a little insulation on the two wires coming from the relay and soldering each bypass wire but a tap (suitcase) connector could be used. Attachment 97221 Your just about done with the pre-wire just need to tape up or heat shrink the wires to keep them neat and together. ---------------------------------------------------------------- Wiring Now that the harness is ready its time to run the wires through the glove box. You can use a coat hanger to fish the wire through to the driverside floor board if it helps. I had the test wires already ther so i used them to pull in the new wires. Attachment 97222 Attachment 97223 Attachment 97224 Now we are going to drop off the two wires for the bypass switch and the ground at the driver-side floor board, then take the two wires connected to pin 30 & 87a and run them through the fire wall. You can run them through the large grommet located above the pedals. Again I used my test wires to help pull them through the fire wall. Attachment 97225 Attachment 97226 You will need to pull them all the way to the fuse box in the drivers side of the engine bay. Attachment 97227 Pop the cover off of the fuse box. Attachment 97228 Thes two connectors will need to be disconnected for the moment. Attachment 97229 Attachment 97230 Disconnect battery. There are two tabs that hold in the small portion of the fuse box that will need to be pulled back to release it. This is where the flat head screw driver comes into play. Hold the tab back with the flat head and gently pull up on the small section. Keep holding it up while you swap over to the other tab and do the same thing. Attachment 97231 Attachment 97232 Pull out the small section of the fuse box and place it out of the way. next unplug the brown cube relay. Attachment 97233 There are three tabs on the large portion of the fuse box, hold those back to be able to pull the large portion up. Attachment 97234 Attachment 97235 Attachment 97236 Pull up that portion and lean it back so you can see the wires under the micro fuses. Attachment 97237 There is a black wire we need to get to that is under the blue 15 amp fuse. Attachment 97238 Find that wire and gently pull a little slack towards you, then cut the wire in half but leave enough to work with. You will be dealing with both halves of this wire. Attachment 97239 Attachment 97240 Now have a sip of coffee while your soldering iron heats up. Attachment 97241 Take one of the wires you pulled into the engine bay (doesnt matter which one) and solder it to one of the wires you just cut. It was cold so was kinda hard to heat the solder up with this cheap iron i have. Attachment 97242 The next step is optional but is good to have done if you ever get rid of the fic or just dont want the 2 step anymore. Crimp on a female spade connector to the two newly soldered wires and heat shrink over the hole deal. Attachment 97243 Attachment 97244 Attachment 97245 Solder the two remaining wires together and crimp on a male connector. Heat shrink the connection and terminal. Now stuff the wires down in the fuse box and close everything up. Don't forget to put those two connectors we unplugged back in their homes. Now we can move on over to the driver side floorboard. Pull open the kick panel and pop out a switch blank from the dash. Attachment 97246 Attachment 97247 Run your bypass wires up and out of the dash and zip tie them as you go. Also would be a good time to zip tie the other wires out of the way that we ran earlier. Connect the wires to the toggle switch (spst) and if needed use shrink tube to cover the connections. Attachment 97248 Attachment 97249 Attachment 97250 Now here comes the hard part of the whole thing, mounting the limit switch (micro switch). You can either use velcro tape (double sided tape even) and zipties togather to accomplish this or a 1"-1 1/4" thin self taping sheet metal screw. If using the screw then this is of course were the mini drill comes into play. I used a the screw. Attachment 97251 It needs to be mounted so when the pedal goes down it trips the switch. Now you need a good ground, I used a short piece of wire and crimped a loop on one end and a female spade connector on the other, then I took the loop end to the closest stud. After i pluged in the spade end to the common pin on the limit switch (micro switch). Attachment 97252 Attachment 97253 Remember that ground we wired up to the relay that we dropped off in the floorboard, yep we need to route it to the "normally open" pin on the limit switch. Zip tie it as you go. Feel free to check all your connections with a multi-meter. Also there are other ways of doing this so use your imagination. ---------------------------------------------------------------- The Magic (set up) Here we are in the home stretch!!! Plug in the fic harness, plug in fic, plug in usb to fic, plug in usb to laptop. Open up the fic program Click file (on the top tool bar), click on open, click on your current map and click open. Click on ecu (tool bar at the top) and click connect. Click on set-up, scroll down to system and click it. Attachment 97254 This screen will pop up Attachment 97255 Look at the lower right hand corner of the system screen, you will see a box labeled "Switched 12Vdc". Set all the parameters in that box to zero. Attachment 97256 Set the rpm on to desired number and the rpm off to desired number. On the latest vid i set mine to 4000rpm on and 4000rpm off ---------------------------------------------------------------- The Reward http://i264.photobucket.com/albums/i...h_MVI_1801.jpg just some after thoughts. If I were to replace my exhaust (which it will get replaced soon) and get rid of the cats (which they will go by by after turbo install) you would prolly have the loud poping and fire balls that are more common to 2step launch control units. also if anyone is having trouble finding the parts i listed or would like to have their harness prewired pm me |
+1,000 internetz for that.:clap::clap::clap::clap:
That is sooo cool
It must be the ricer in me but I love the way the WOT Box bounces at the set RPM instead of the RPM's staying steady LOL |
Nice work man, can't wait for more details. I have been so busy with my engine build I haven't even gotta a change to mess with anything more than fuel and o2 maps in the fi/c let alone devise a launch control mechanism :clap:
awesome. Looking very forward to the DIY
Didn't know the aem fic could have the 2step.
interesting... i wonder how this would be building boost and if it would actually work nicely at the track
nice.. did you do full throttle on that one?
damn Chris, that is cool. I don't have ricer in me sooo, I like the steady/quiet rather than, OH snap that engine is about to blow! sound
I been very excited about doing this mod for the last month and finally got an fic. been waiting on ups to get me that lost package from yesterday that has the female pins for the fic and they still havent gotten here yet. Im starting to hate ups. anyways there is a few ways of doing this via the fic and i want to try other things first before a diy on it. also need to confirm the reliability and consistancy of this 2step.
Originally Posted by Ace83
(Post 3459737)
Originally Posted by tcturbo07
(Post 3459727)
I would also like to tryout nolift shift aswell, should be pretty much the same as this just one more step added in the process.
that would be nice, also the Wot box people came up with a boost by gear or speed thing. I'm sure u can figure something out too.
^^I thought about that but my plans didnt include using the fic though. I could though configure the fic to be a boost controller, i would have to get a cylinoid though. it will be hard though to get it in the butter zone.
dude this is awesome!!!!!!! props to you... pls link the DIY here.. i need this sooo bad right now lol
how bout anti-lag?
^ thats really cool
wow props man!, i have been wanting to get rid of my stupid n2mb wot box for a while, all it seems to do it throw codes! anyways im watching, very very interested!
good work! |
Originally Posted by brett561tc
(Post 3459689)
good job Chris! |
