driving untuned with internals safe?
Old Mar 11, 2009 | 03:15 AM
turbo_tC4's Avatar
Default driving untuned with internals safe?
i just got my engine rebuilt with K1 connecting rods, Wiseco low comp pistons, and cometic head gasket. My car was previously tuned but didnt finish because my car was smoking burnt oil. So now i have the engine rebuilt and put in along with my turbo kit. The tuner (CFT) said that i was pretty much almost tuned just need some minor stuff to do left to finish it. They're coming down this weekend. I just want to know if it's safe to drive in VAC only and not have any problems. remember i have internals done.
Old Mar 11, 2009 | 04:02 AM
m6ar2cel6oTC's Avatar
what bearings did you use? and did you use main and head studs?
Old Mar 11, 2009 | 04:07 AM
turbo_tC4's Avatar
everything else is stock, i just changed the pistons, rods, and headgasket
Old Mar 11, 2009 | 04:24 AM
you should have changed the bearings and the studs! you shouldnt use the same bearings!
Old Mar 11, 2009 | 04:27 AM
turbo_tC4's Avatar
what could go wrong? and is it safe to drive the car? no boost
Old Mar 11, 2009 | 03:42 PM
jwaggz82's Avatar
ya. bearings and studs for sure - the cost would have been minimal
Old Mar 11, 2009 | 04:13 PM
RSracer's Avatar
ouch, reused OEM bearings... do remeber though if you go to main studs you will have to get your main journals align honed, since the clamping force / characteristics are different than with bolts.
but to answer your question, it's fine to drive it around with out a tune just as long as you stay out of boost. However you plan to break the engine make sure you use conventional oil though. Your rings will not seat properly if you don't and you will have blow by.
Old Mar 30, 2009 | 10:15 PM
deeravenger's Avatar
we did the same to my sons car but we got new head bolts and new bearings. So i can not use snythedic oil to break in the motor?
Old Mar 30, 2009 | 10:45 PM
RSracer's Avatar
no, make sure you use conventional. Basicly synthetic oil basicly does it's job TOO good for fresh rings. Causing the oil to blow by the rings, lubricating them and not allowing them to break in or match the microscopic grooves in the cylinder walls.
Old Mar 31, 2009 | 02:25 AM
ElevationTC's Avatar
u get that thing running?
Old Mar 31, 2009 | 03:12 AM
purevision01's Avatar
Hope that headgasket doesnt leak. Stock head bolts are torque to yield. Meaning they stretch once they were tightened down. Generally, after a torque to yield bolt has been used once it has to be replaced because the bolt bottoms out before the proper torque is achieved.
Old Mar 31, 2009 | 03:13 AM
pure vision ur a tuner correct? u ever mess with o2 feedback on the aem ems?
Old Mar 31, 2009 | 04:27 AM
BlackKnight's Avatar
Music City Scions
Doesn’t matter if you use ARP head studs or stock head bolts. You should never, never reuse head bolts, main studs, or rod studs. Every single time (no matter what we are referring stock or brand name) you torque bolts they loose there strength. We had someone come to our maintenance shop and give a demonstration (keep in mind I don’t remember the actual numbers, these are only examples) the first time he torqued the bolt down day we went to 100ft lbs of tq the psi was 1200. After taking the nut and bolt apart, we re-torqued it the second time (keeping the torque wrench set exactly the same) it was sitting around 950psi, after a third time of doing this the psi went to 750. Just so you are following this is using a pressure gauge to measure the pressure the bolt will be at once properly torqued.
Old Mar 31, 2009 | 08:24 PM
Never fudged around with it. Don't have the ems on my car.
my06tc
Jun 25, 2015 12:18 AM
randompacking
Jan 28, 2015 11:43 AM
evolving_machine
Jan 13, 2015 08:04 PM
umnitza
Dec 1, 2014 06:26 PM
TheRedBox
Oct 8, 2003 04:25 PM
