Dyno APP'S
Im not a fan of the F/IC for a tC, so was just wondering if it was an independent software app.
You also don't even need AEMLog to analyze the data. Before I had the logging program, I was able to run the calculations from the DynoMaths library in an Excel spreadsheet. I just imported the data logs, entered the calculations into the proper spreadsheet cells, and I was able to calculate the horsepower. All horsepower and torque numbers are is a series of calculations derived from a few logged parameters.
That's pretty sweet. I will check that out.
I just got looking at the logic behind the DynoMaths library again to re-familiarize myself with the calculations again. This info has been copied from the DynoMaths thread on AEMPower.com and modified for the tC. Below are all of the inputs you need to figure out your car's horsepower:
Logged Inputs:
Time: Optimal sampling is 250 samples per second. Lower sampling rates can work, but aren't as accurate.
Engine RPM: Need to be logged at sampling interval.
Static Inputs:
Wheel Size: Wheel size, in inches. In 225/40ZR18, this is the 18.
Tire Width: Tire width, in mm. In 225/40ZR18, this is the 225.
Tire Aspect: Tire aspect ratio. In 225/40ZR18, this is the 40.
Gear Ratio: Gear ratio of the gear you're doing pulls in. (3rd gear is 1.33 in the tC)
Drive Ratio: Final drive ratio of your car. (tC is 4.235)
Weight: Weight of your car, in pounds. Very important to get this accurate.
Optional Inputs: (for the most accurate results)
CD_DRAG: Coefficient of drag for your car. (.32 on a stock tC)
CD_AREA: Frontal area of your car, in square feet. (24.2 square feet on a stock tC)
Logged Inputs:
Static Inputs:
so how much power do you guys get on the dynolicious? we tried it today, my friends M3 auto convertible runs 14.3 1/4 mile top HP 226, my friend's nismo z only had top hp 190+, mine only had 150+hp 16sec 1/4 mile.. the z and my tc had very poor start though, i have to roll the car to 5-10mph before i can dump the gas otherwise my car will stall-
Logged Inputs:
Static Inputs:
Logged Inputs:
Static Inputs:
I was messing around and did a 3rd gear pull and it said I run a 9 1/4mile and produce 130 wheel..... I think I did it wrong
Sent from my DROID incredible
NonStopTuning
Scion FR-S Drivetrain & Power
14
May 5, 2017 06:52 PM
edwinisdumb15
Regional - Pacific South
Sep 18, 2015 10:48 PM
edwinisdumb15
Sep 13, 2015 12:44 AM
carid
Aug 31, 2015 11:17 AM
marsman328
Regional - Pacific Mid
Jul 28, 2015 09:43 PM
