E85 Timing
Old Sep 15, 2010 | 07:34 PM
  #61
trd07tc's Avatar
Originally Posted by coryjames
Or twin wallys
if you are looking for flow. bosch 044 if you are looking to raise pressure
Old Sep 15, 2010 | 10:46 PM
  #62
Ace83's Avatar
Ronin Scion
Originally Posted by thendawg
Oh yeah, and cory, I know you live in the cold lol - so is there anything I can do with my FIC to make cold starts on E85 easier? possibly more fuel in the first couple cells (startup)? Possibly pull some timing in those cells?
I think our ecu has some good enrichment strategies already built in, plus ignition advance to make good cold starts. You will just need to tweak it for the winter.. on the summer you will need to change the start up area. It will be a challenge i think for piggybacks to use one summer and winter tune esp on extreme temps changes
Old Sep 16, 2010 | 12:07 AM
  #63
Rasta's Avatar
One should always stay conservative on timing...use boost to make the power especially with e85. Timing equals...KABOOM!..One thing I noticed you will hardly ever get knock with E85. In time however if your making over 350whp them stock rods are going to buckle like never before..guranteeeeeddddd.
Old Sep 16, 2010 | 12:38 AM
  #64
m6ar2cel6oTC's Avatar
with e85 you can run more timing.
Old Sep 16, 2010 | 01:19 AM
  #65
SoFloTC's Avatar
what kinda of timing are u guys pulling on pump? im super conservative right now at like -10 in higher rpm's in wot at 10 psi and im pretty sure im at 300whp right now.
Old Sep 16, 2010 | 01:32 AM
  #66
coryjames's Avatar
10k on 10-17 pounds made over 400wtq drive it hard im buying time
Old Sep 18, 2010 | 02:04 PM
  #67
Rasta's Avatar
Agreed, however timing is not the safest way to make power. I run on E85 my self, not too crazy on the timing more boost.
Old Sep 18, 2010 | 08:21 PM
  #68
Ace83's Avatar
Ronin Scion
preignition is still a concern with e85 especially if you add too much timing
Old Sep 18, 2010 | 09:17 PM
  #69
ElevationTC's Avatar
^^ this!
You cannot street tune E85.
Old Sep 18, 2010 | 09:29 PM
  #70
trd07tc's Avatar
Its still a concern but you are not taking full advantage of switching to the fuel unless you are adding boost and a few degrees of timing over a 93 map
Old Sep 18, 2010 | 11:39 PM
  #71
blown_xa's Avatar
Originally Posted by ElevationTC
^^ this!
I agree. You cannot optimize timing street tuning, period. The dyno is the only way. MBT is MBT, only a dyno graph will show it. I ran 9 degrees advanced timing near redline with WMI on pump gas.... nobody would have the ***** to just plug in those numbers street tuning, that's asking for detonation.
You need to get the timing where it needs to be, if it is too "conservative" as some say your egt's will skyrocket.
Old Sep 19, 2010 | 12:25 AM
  #72
Ace83's Avatar
Ronin Scion
there you go, MBT is MBT.. really no point adding more timing if MBT is reached unless the goal is destroying the motor
Old Sep 19, 2010 | 06:43 AM
  #73
trd07tc's Avatar
You should know where your timing needs to be or you should not even be tuning
Old Sep 20, 2010 | 12:12 AM
  #74
coryjames's Avatar
my car is street tuned all day every day
went to a dyno threw down 400 some people are just cow boys. im now running 17-19 psi stock motor feels to be about 50 hp i love the ethanol. btw im trying to pop my motor build this winter if not another stock motor one localy for 300 with 27k on it
Old Sep 20, 2010 | 12:56 AM
  #75
blown_xa's Avatar
I had to think about this for a few minutes... at first, it made no sense to me. I think what you are saying is one should have the smarts to have a "general" idea on where the timing should be?
I have a 50 trim t3/4 turbo with a .63 exhaust housing running 9.8 to 1 compression with a 100ml wmi jet and a 35% meth mix. I want to run 22 psi. Where should my timing be?
I don't know anyone in the world who could answer that question without Dyno tuning the car.
Beyond that, WOT is one thing, but optimizing timing (especially with a standalone) can ONLY be done on a dyno.
" ok lets drive up a hill at -15 vacume @ 3000 rpm, my butt feels an increase in tractive effort" LOL "
Old Sep 20, 2010 | 01:00 AM
  #76
Uhm, 14 degrees during peak tq and tapering to 17 !
LOL
Old Sep 20, 2010 | 01:21 AM
  #77
blown_xa's Avatar
LOL
UR a MASTER TUNER!
Old Sep 20, 2010 | 01:40 AM
  #78
trd07tc's Avatar
ugh
of course your not going to know the EXACT MBT but you should have a general idea of where your timing needs to be
you people are too literal
Old Sep 20, 2010 | 02:12 AM
  #79
UR a MASTER TUNER!
Lol,
Its gotta be kinda close
  #80
thendawg's Avatar
So, this isnt really a build thread, but I ran at the track today at IFO... It was 95-98* out all day - it sucked bad
On street tires = bad idea
Best time was like a 14.2 lol
Traps were between 110-112
Also I was getting massive heatsoak - iat's were really high and causing it to run really rich - like 10.5-11.0 (on a gas scale)
This was on my setup on 17 psi (built bottom end - 9:1 comp, E85, 60-1)
Should be going to a local track soon at night in oct when the temps are 60-70
