ecko04 - Bye-Bye tC - Trading in soon
Originally Posted by ecko04
Originally Posted by BlackKnight
If he is pulling information from the AEM FIC then he needs to make sure the sensor setting is correct. Does the FIC read the OEM Lambda sensor?
The reason i'm saying Lethal's is wrong is simply because had they really really tuned using AFR they wouldn't did something to the O2 map. There is no way coming right out the gate that the O2 map should be all 0's at the end of the tune. It isn't that dang perfect as evident when I went to pick the car up.
is a way to get it to display that info unless you hacked the fic.
but yeah you got the idea
btw ecko did you send me a log?
Rob told me how to hook up the UEGO to the FIC and PC log so I have tons of those now. None, with the original poop tune though.
its cool...i had just seen that someone sent me a log and i tried to view it but there was no info on it...
throw a new one my way...id like to see how everything is working out for ya.
im sure B-Real took good care of ya...also send me your tune that your using with that log
send me ur tune and log as well.. id like to take a look.
Mike@theautospecialist.net
or
mike@elevationaudio.com
or
Update 6/15/2009
I took care of my last remaining exhaust leak this morning.
Took the car out to a secluded spot and took off the exhaust manifold, I cleaned the gasket with some soapy water and cleaned the mani with soapy water. I sealed the gasket up with RTV on both sides, put the manifold back on and tightened the bolts.
Cure time for the RTV was 1 hour but i'm sure that passed by the time I got the downpipe bolted back up, removed the reminisce of my VRD fog lights, put the IC piping back on the turbocharger, etc.
Fired it up and the AFR's looked like they should. I placed my hand over the top of the exhaust mani and felt no air
I took it out for one quick run, cruise and idle AFR between 14 and 15, boost between 11 and 12.
Came back to the apartment to the smell of burning oil, looked under the car and saw no oil, looked under the hood and saw my turbo oil feed line which was already garbage from the previous user not really sealed. Got out my wrench and realized it wasn't getting any tighter, inspected it and saw I needed another since if I swapped ends the other end connected fine and tightened down.
Ordered one from Dezod this morning and it'll be here tomorrow so I can make it to class
So I don't have a turbo oil feed line so i'll be eating whatever can be delivered for dinner. Oh and the RTV had all day to sit, cure and make that leak proof gasket that we all know and love.
Originally Posted by weezyfbayba
so how does it feel to be boosted bro? i can't wait should have my kit installed in a month
Originally Posted by Skeeeett
let me kno how the blow thru works out for you, i was thinking about doin that myself but never heard anyone really talk about it
The reason I was asking about what you were using to read your AFR is I have a AEM wideband UEGO located in the downpipe and my AFR was on part to Lethals Dyno. If you are using the readings from the AEM it may be off and need to be calibrated or you may be reading the narrow band sensor.
Sounds like the same thing the Ultimate has when you plug in the A/F ratio harness to hook up to a Wideband for the A/F Target map.
Glad to see people are catching on to this. I first saw it on PTuning's TA car and World Racing's TA car. Then I did it to mine, and reported that people shouldn't waste money on some "magical" gasket, and just use RTV around the exhaust ports.
I think I have an exhaust leak between down-pipe and s-pipe (go figure, TT fitment is off). Think it'll work? I don't even know if that's the leak, but I'm pretty sure there is a leak somewhere. It HAS to be the reason for my car being so stinky.
