Emanage Ultimate Help
Old Nov 1, 2006 | 05:53 PM
318_tC's Avatar
Default Emanage Ultimate Help
With Ultimate can you control when signal is sent to the ignition coil?
Old Nov 2, 2006 | 04:22 AM
soros151's Avatar
watching
Old Nov 2, 2006 | 06:13 AM
Joe_Dezod's Avatar
You can advance or retard the ignition timing. It only works in closed loop (WOT), and simply alters the spark timing from the TDC point of the motor.
Old Nov 2, 2006 | 01:37 PM
318_tC's Avatar
Will that fix my problem?
at 14psi after driving a bit and i sit at idle for like 3-4 mins i blow a coil pack
Old Nov 2, 2006 | 04:32 PM
PghtC's Avatar
ouch. tough question.
Old Nov 2, 2006 | 04:39 PM
soros151's Avatar
Wow wow wow, blown coil pack? How much was to replace it?
318_tC's Avatar
exactly, and the car sits till i get a answer....
Old Nov 2, 2006 | 04:43 PM
ProshopXB's Avatar
I dont unsderstand why you dont just call Paul and find out the answer?
But it is a very sucky and expensive situation...
Old Nov 2, 2006 | 05:04 PM
318_tC's Avatar
pwned by sema.
Im getting ____ed at this point
Old Nov 2, 2006 | 06:35 PM
ZPIracing's Avatar
What does the map look like......how much timing are you puling out at part throttle?
We have had this issue before not on a tC you may need to install diodes in line...I think you can adjust the tune...I can give you the part # next week when i am back at the shop...
ZPI mobile tech support ......over and out
Old Nov 2, 2006 | 07:17 PM
318_tC's Avatar
Thanks I appreciate it, im rdy to get back on the road!!!
Old Nov 3, 2006 | 12:42 AM
paul_dezod's Avatar
Scionetics
KAD
Jeff, did St00pid tune it?
BTW, your diodes you need should have been included with the e-manage box from GReddy if I recall correctly. If not, you can scoop some at a local Radio Shack.
Old Nov 3, 2006 | 02:06 PM
318_tC's Avatar
im gonna try to get the map emailed to me
TBurleson
Jan 28, 2019 12:57 AM
BlackKnight
Sep 15, 2015 06:42 AM
carid
Aug 31, 2015 11:17 AM
Subaru86
Jul 31, 2015 04:00 AM
TheTripleC
Jan 4, 2015 06:46 PM
